Posted June 28, 200321 yr comment_42335 my car has a strange wobble to it like one of the wheels were bent or somting. but wheni drive on the freeway, u cant really notice it. its when u drive slow that u notice it the most. what can it be? Link to comment https://www.classiczcars.com/forums/topic/6810-wobbly/ Share on other sites More sharing options...
June 29, 200321 yr comment_42368 Could be a faulty tyre. I had an old car that had a lump in the tyre that did exactly the same thing. you only noticed it when going slow, like pulling up to a set of stop lights.Could also be tyres out of alignment or balance, but that would probably get worse the faster you go. Does you steering whell shake.Could be a bent rim also. I'd have it professionally looked at by tyre/suspension guys. You dont want to be driving down the freeway at 60mph and have a tyre blow out. Link to comment https://www.classiczcars.com/forums/topic/6810-wobbly/#findComment-42368 Share on other sites More sharing options...
June 29, 200321 yr comment_42389 I've noticed recently my car has a similar issue.When I reverse out of my driveway and turn the steering wheel all the way to one side when I get onto the street as the car moves I can feel a like skipping as if something was broken or worn out.I've replaced my tie rods, most front end bushes, and ball joints. I have no idea the wheels seem to be of good pressure and I had it balanced recently and there was no problem till about 2 weeks after.Can't work it out and am really unsure car drives fine at higher speeds other than manoeuvering speeds.I do have a rear tyre that get's flat because of a nail stuck in it which i'm gonna be taking care of but I'm pretty sure it still happens after I've just pumped it back up so don't think it's that.Also it's been like that for a while.I haven't been hitting into kerbs or doing anything silly to damage the rims either.Unless someone drove my car when I didn't know which really could not of happened to my knowledge.:sleepy: Link to comment https://www.classiczcars.com/forums/topic/6810-wobbly/#findComment-42389 Share on other sites More sharing options...
June 29, 200321 yr comment_42395 here is a list of things to check.suspension parts ietie rod ends, ball joints, tc rod, bushings, wheel bearingscheck the tire for being out of round, wheel damage, balance, lost balance weightscheck your steering rack for play as well, and the associated bushings, and of course make sure your wheel is attached properly Link to comment https://www.classiczcars.com/forums/topic/6810-wobbly/#findComment-42395 Share on other sites More sharing options...
