Posted February 8, 20232 yr comment_650083 I'm doing a trans swap (auto - manual) as part of my 73 restoration. I want to run the hydraulic line from the clutch master cylinder to the frame bracket while I have the engine out of the car. I have the metal bracket that mounts on top or the right frame rail but I'm not sure where to mount it, since the auto trans cars did not have it. Can anyone give me an approx. measurement for the location on the frame rail? This is the bracket that handles the transition from the hydraulic metal line to the rubber hose that connects to the slave cylinder. I hate to have to put the engine in to determine the location, then take the engine back out to fabricate the line and weld the bracket in. As always, thanks in advance. z3beemer (Paul) Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/ Share on other sites More sharing options...
February 8, 20232 yr comment_650087 On #375 from Restoration of BringaTrailer 240z - HLS30-35883 you see a video of a manual body, and the requested location of the part! Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650087 Share on other sites More sharing options...
February 8, 20232 yr comment_650090 Here are two pics - one without the hard lines and one with them in place. If you can obtain a clutch hard line from a parts car, it should help you to position the bracket on the frame rail. Hope this helps. Edited February 8, 20232 yr by jfa.series1 Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650090 Share on other sites More sharing options...
February 10, 20232 yr Author comment_650123 Thanks for the pics. They are most helpful. Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650123 Share on other sites More sharing options...
February 10, 20232 yr comment_650131 Here are a couple more pix showing this area with a line and slave attached. Edited February 10, 20232 yr by texasz Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650131 Share on other sites More sharing options...
February 10, 20232 yr comment_650137 4 hours ago, texasz said: Here are a couple more pix showing this area with a line and slave attached. I guess I don't have access to these pictures. One question on this... Is that tab that the clutch hard line connects to there on an AT car? Edited February 10, 20232 yr by w3wilkes Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650137 Share on other sites More sharing options...
February 10, 20232 yr comment_650138 1 hour ago, w3wilkes said: I guess I don't have access to these pictures. One question on this... Is that tab that the clutch hard line connects to there on an AT car? Have a look now, I've attached them differently this time. I would suspect that the tab would be there since when the body was built they likely did not do things differently for AT/MT due to cost of tooling change etc. Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650138 Share on other sites More sharing options...
February 10, 20232 yr comment_650139 2 hours ago, texasz said: Have a look now, I've attached them differently this time. Thanks, now I can see the pictures! Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650139 Share on other sites More sharing options...
February 11, 20232 yr comment_650144 Tabs not there as I found out when I did my conversion. ZCD has the bracket if you haven’t procured one yet. Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650144 Share on other sites More sharing options...
February 11, 20232 yr comment_650146 21 minutes ago, Yarb said: Tabs not there as I found out when I did my conversion. ZCD has the bracket if you haven’t procured one yet. Here's what @Yarb is talking about: https://zcardepot.com/products/clutch-hose-metal-tab-frame-rail-510-240z-260z-280z Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650146 Share on other sites More sharing options...
February 13, 20232 yr comment_650225 On 2/10/2023 at 8:50 PM, Yarb said: Tabs not there as I found out when I did my conversion. ZCD has the bracket if you haven’t procured one yet. And I continue learning new things about these cars every day, tank you @Yarb! On 2/10/2023 at 9:11 PM, SteveJ said: Here's what @Yarb is talking about: https://zcardepot.com/products/clutch-hose-metal-tab-frame-rail-510-240z-260z-280z Thank you for the link @SteveJ. Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650225 Share on other sites More sharing options...
February 13, 20232 yr comment_650230 On 2/10/2023 at 11:02 AM, w3wilkes said: I guess I don't have access to these pictures. One question on this... Is that tab that the clutch hard line connects to there on an AT car? On 2/10/2023 at 12:18 PM, texasz said: I would suspect that the tab would be there since when the body was built they likely did not do things differently for AT/MT due to cost of tooling change etc. No, the bracket wasn’t attached during manufacturing of cars with automatic transmissions. Another difference is the shifter opening in the transmission tunnel. If I recall correctly, it is forward of what a manual transmission car would have, by an inch or two. I’ve seen other posts where the swap was done, and the rear portion was cut out, turned around and reattached at the forward end of the opening. Also missing on automatic equipped cars is the stop on the floor/firewall for the clutch pedal. Edited February 13, 20232 yr by Racer X Link to comment https://www.classiczcars.com/forums/topic/68127-hydraulic-clutch-line-mounting-bracket-location/#findComment-650230 Share on other sites More sharing options...
