March 1, 20232 yr comment_650871 Thats the issue Iwas having the other day. Even my own profile Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-650871 Share on other sites More sharing options...
March 1, 20232 yr Author comment_650874 Well, thanks for derailing my thread.. issue fixed. 😛 Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-650874 Share on other sites More sharing options...
March 1, 20232 yr comment_650912 10 hours ago, Mike said: Well, thanks for derailing my thread.. issue fixed. 😛 Sorry, eh? Oh, and thanks. Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-650912 Share on other sites More sharing options...
March 3, 20232 yr comment_651010 Totally agree with @hs30-h here!!I was initially wowed by it but then realised the SISO principle holds well when I started to research some of my other bad Japanese obsession / passion - namely Shotokan Karate. Long story short, like other AI that quickly became sexist / racist etc - it’s scanning for loudest most repeated voices and learning from it, building it’s own pattern biases in order to regurgitate and “enrich” with choice bits from other sources.Did you know that recruitment AI decided men were better to employ than women? Or that self driving AI was way more likely run over black women due to its learning bias introduced by observing white men? Or stranger still that it didn’t initially recognise pedestrians unless they were at a pedestrian crossing scenario? Scary new world we are about to live in!Having said all that, it’s still impressive capabilities in their embryonic state. Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651010 Share on other sites More sharing options...
March 4, 20232 yr comment_651018 I've heard it as GIGO. Garbage in, garbage out. When I think of "shite out" it starts with food. AI plus the Google ad algorithm will be when things get really bad. Artificial people talking about crap you really don't care about. Can't wait! Edited March 4, 20232 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651018 Share on other sites More sharing options...
March 4, 20232 yr comment_651021 Should be interesting when the first AI Bot registers on this forum and starts doling out tech advice. Hopefully, Google's AI, Bard, will be better when it's released.....or escapes. I've used it and it has a way to go just like Microsoft's AI. Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651021 Share on other sites More sharing options...
March 5, 20232 yr comment_651068 So I had to! I was bored on the loo and asked chatgpt to write me a poem about a 240z:The 240Z, a car that roarsA legend of speed, forever adoredWith a sleek design and power to spareThis car was made for those who dareIts engine purrs like a tiger in the nightAs it takes off with all its mightThe curves and lines, a beauty to beholdIts spirit and soul, never to be soldOn the open road, it's pure poetryA symphony of metal, speed, and gloryIts timeless charm, a classic so rareA legend that still turns heads everywhereFor those who love the thrill of the rideThe 240Z will forever be a source of prideA car that's etched in historyA symbol of speed, passion, and victory.Not bad eh!? Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651068 Share on other sites More sharing options...
March 5, 20232 yr comment_651070 Actually... it is bad. Bland. It leaves me empty, devoid of emotion. Not bad for a grade schooler though. And, 240Z's aren't known for power or roaring. The AI being must have scavenged from Hybridz. Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651070 Share on other sites More sharing options...
March 5, 20232 yr comment_651075 Ask it something technical, like how to adjust valve lash on a Datsun engine. Or change a tire. Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651075 Share on other sites More sharing options...
March 5, 20232 yr comment_651076 I asked as you suggested and got this:Adjusting the valve lash on an L28 engine involves several steps, and it's important to follow the manufacturer's specifications to ensure proper engine performance. Here is a general guide on how to adjust valve lash on an L28 engine:Start by removing the valve cover and locating the camshaft and rocker arms. The L28 engine has 12 rocker arms, six for the intake valves and six for the exhaust valves.Rotate the engine until the camshaft lobe for the valve you want to adjust is pointing upwards. You can use a wrench to turn the crankshaft bolt or use the starter motor to turn the engine.Using a feeler gauge, measure the gap between the rocker arm and the valve stem. The correct valve lash specification for the L28 engine is 0.010 inches (0.25mm) for the intake valves and 0.012 inches (0.30mm) for the exhaust valves.If the valve lash is not within the specified range, loosen the locknut on the rocker arm and adjust the clearance by turning the adjusting screw. Then, tighten the locknut to secure the adjustment.Repeat the process for all 12 valves, rotating the engine as needed to access each valve.Once all the valves have been adjusted, reinstall the valve cover and start the engine to verify proper operation and ensure there are no leaks.It's important to note that the L28 engine has a specific valve lash adjustment sequence that should be followed to ensure proper operation. It's recommended to refer to the manufacturer's service manual or consult with a qualified mechanic for specific instructions on adjusting the valve lash on an L28 engine.Sent from my iPhone using Tapatalk Pro Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651076 Share on other sites More sharing options...
March 5, 20232 yr comment_651077 FAIL! Didn't mention hot or cold. Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651077 Share on other sites More sharing options...
March 6, 20232 yr comment_651087 Another fail: "Using a feeler gauge, measure the gap between the rocker arm and the valve stem." Not happening... Link to comment https://www.classiczcars.com/forums/topic/68164-chat-gpt-ai-bot/?&page=2#findComment-651087 Share on other sites More sharing options...
