Posted March 2, 20232 yr comment_650974 I am putting my steering column back in. Wondering which way the coupler bolts go. My pictures prior to taking the car apart show the nuts towards the steering rack. When I look at the parts diagram it shows the nuts towards the firewall (#30,31,32). Just trying to figure out where my nuts go 🙂 Link to comment https://www.classiczcars.com/forums/topic/68176-steering-coupler-bolts-72-240/ Share on other sites More sharing options...
March 2, 20232 yr comment_650977 My 7/70 car is like this, what year is your car? just saw you put year in the topic title. 🙂 Edited March 2, 20232 yr by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/68176-steering-coupler-bolts-72-240/#findComment-650977 Share on other sites More sharing options...
March 2, 20232 yr comment_650982 Here is a screen grab from a video I took prior to disassembly for my current resto. Also the FSM is your friend, here's an image from my 1970 FSM, steering section. The 72 FSM shows the same orientation. Edited March 2, 20232 yr by CanTechZ Link to comment https://www.classiczcars.com/forums/topic/68176-steering-coupler-bolts-72-240/#findComment-650982 Share on other sites More sharing options...
March 2, 20232 yr comment_650987 Both of my Z's had the bolts oriented with nuts on the lower side (12/70 and 6/71 production dates) Link to comment https://www.classiczcars.com/forums/topic/68176-steering-coupler-bolts-72-240/#findComment-650987 Share on other sites More sharing options...
March 2, 20232 yr comment_650989 FYI on these bolts, two of them are quite fussy to remove/install and would be impossible to do in the OE orientation if you don't use the correct JIS head bolts. If DIN bolts with larger hex heads were substituted they would need to be reversed. Not that anyone should be making substitutions when it comes to steering bolts. Just my two cents worth. Link to comment https://www.classiczcars.com/forums/topic/68176-steering-coupler-bolts-72-240/#findComment-650989 Share on other sites More sharing options...
March 3, 20232 yr Author comment_650991 Thanks for the replies. I have found a couple of instances when the parts manuals didn't match what I thought was correct. I guess the FSM is the better document. I only use JIS hardware, and let me tell you, I have had to replace a lot of hardware that wasn't correct! I took a ton of spare hardware and had it replated along with other stuff. Between that and Belmetric it has been invaluable. Link to comment https://www.classiczcars.com/forums/topic/68176-steering-coupler-bolts-72-240/#findComment-650991 Share on other sites More sharing options...
