Posted March 21, 20232 yr comment_651645 I may have a line on a used dashboard which hopefully is in acceptable condition for the Z restoration I'm currently working on. Looks like there are three versions of dashes for the S30's over the years, however from 1974 to 1978 they all have the same dash. Could someone with knowledge of dash versions confirm if this is correct please? Thanks, Jim Link to comment https://www.classiczcars.com/forums/topic/68212-various-z-dashboard-versions-240-260-280/ Share on other sites More sharing options...
March 21, 20232 yr comment_651648 Post #9 Link to comment https://www.classiczcars.com/forums/topic/68212-various-z-dashboard-versions-240-260-280/#findComment-651648 Share on other sites More sharing options...
March 21, 20232 yr Author comment_651649 siteunseen, thanks for that. That tells me essentially what I need to know which is all 280's have the same dash. Jim Link to comment https://www.classiczcars.com/forums/topic/68212-various-z-dashboard-versions-240-260-280/#findComment-651649 Share on other sites More sharing options...
March 21, 20232 yr comment_651650 1 hour ago, JimT said: siteunseen, thanks for that. That tells me essentially what I need to know which is all 280's have the same dash. Jim The early 260Z has the same dash as the 280Z, as indicated here: https://www.carpartsmanual.com/datsun/Z-1969-1978/body-260z-280z/2-seater/instrument-dash-side The 73 240Z dash is different from the earlier dashes. Link to comment https://www.classiczcars.com/forums/topic/68212-various-z-dashboard-versions-240-260-280/#findComment-651650 Share on other sites More sharing options...
