I may have a line on a used dashboard which hopefully is in acceptable condition for the Z restoration I'm currently working on.   Looks like there are three versions of dashes for the S30's over the years, however from 1974 to 1978 they all have the same dash.   Could someone with knowledge of dash versions confirm if this is correct please?
Thanks,
Jim
1 hour ago, JimT said:
siteunseen, thanks for that.  That tells me essentially what I need to know which is all 280's have the same dash.
Jim
The early 260Z has the same dash as the 280Z, as indicated here: https://www.carpartsmanual.com/datsun/Z-1969-1978/body-260z-280z/2-seater/instrument-dash-side
The 73 240Z dash is different from the earlier dashes.
