I bought a used steering wheel off eBay, listed as applicable to 240/260/280Z, as mine is 'squishy". The listing implied it was a factory wheel, and it appears to be. The problem is it has no hub, and since I'm new to Datsun, I didn't realize that the stock wheel in my 75 is not detachable from it's hub.
So, Can anyone advise me on what hub I need to look for to make this wheel work? Thanks in advance
image from listing, it specified without  hub or horn button shown
Edited by HusseinHolland
  • 3 weeks later...
Still haven't figured this out, so I bought a cheap universal wheel (Nardi/Personal/Momo) Boss kit HUB-N-2 that allowed me to use an old Nardi wheel I had stashed.
I'll need to find a 48mm Datsun emblem to replace the Abarth emblem. This will do until I figure out a way to use the Datsun wheel.
New dash is here, so that will be on the agenda
8 hours ago, heyitsrama said:
Thanks - that's actually the same as what I used to mount the Nardi wheel. The old Datsun wheel I need the hub for has 2 3-bolt mount patterns, one with 6.5mm holes the other with 8mm holes, 48mm bolt spacing
  • 2 months later...
17 hours ago, HusseinHolland said:
Because I like the one I bought, it's period correct. Still no luck on a hub, so it's a moot point
Good enough reason...just trying to suggest another route to get you behind the wheel. All the best...Ryals
Modified the vintage aftermarket wheel to fit. Cut the hub from the original worn out wheel. The advantage of this is that it will sit further away from me. With my height, the stock wheel is too close to me when the seat is correctly placed for clutch pedal operation. This wheel is shallower.
welded after this - forgot to take pics
added JB weld to fill the minor gapage on the front side
