April 2, 20232 yr Author comment_652093 I messed with mine when tuning it with an air fuel gauge but marked all the original positions so I could reset it when I try this... Link to comment https://www.classiczcars.com/forums/topic/68237-temp-sensor-resistor/?&page=3#findComment-652093 Share on other sites More sharing options...
April 3, 20232 yr comment_652096 On 4/1/2023 at 6:32 PM, chaseincats said: Could you take a couple pictures of the installation instructions? Cliff beat me to it. Thanks @siteunseen Link to comment https://www.classiczcars.com/forums/topic/68237-temp-sensor-resistor/?&page=3#findComment-652096 Share on other sites More sharing options...
April 4, 20232 yr Author comment_652143 To tune the car with the air fuel gauge I leaned the car out 3 teeth on the black gear. Adding the potentiometer, being a resistor, would only serve the purpose of richening the car, right? So in theory, to modify the curve with the potentiometer, I’d need to first lean the car out a few more teeth on the AFM before I could successfully get some wiggle room to richen it, right? As I understand it, plugging the potentiometer in and turning the dial to the smallest level of resistance would essentially be as lean as I could make the car without messing with the AFM, correct? Link to comment https://www.classiczcars.com/forums/topic/68237-temp-sensor-resistor/?&page=3#findComment-652143 Share on other sites More sharing options...
April 9, 20232 yr Author comment_652305 Anyone? Maybe I'm not understanding this Link to comment https://www.classiczcars.com/forums/topic/68237-temp-sensor-resistor/?&page=3#findComment-652305 Share on other sites More sharing options...
