Posted April 1, 20232 yr comment_652010 I've never seen it but what z or zx has this on the rear of the starter? Maybe on a 280z as i never owned that type.. but what's the function of this rubber grommet on the end of this starter? I can't think of anything.. under that rear part are the brushes and the collector.. Thanks ! Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/ Share on other sites More sharing options...
April 1, 20232 yr comment_652011 That's to drain off the extra electrons so they don't fill up the starter. Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652011 Share on other sites More sharing options...
April 1, 20232 yr Popular Post comment_652012 Â Or if it's Lucas, it's a smoke fitting. Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652012 Share on other sites More sharing options...
April 1, 20232 yr Author comment_652013 I thought maybe it's for coolant in/out from a AC equipped version? sigh.. Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652013 Share on other sites More sharing options...
April 1, 20232 yr comment_652014 31 minutes ago, Mark Maras said: Â Or if it's Lucas, it's a smoke fitting. Home Before Dark!! Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652014 Share on other sites More sharing options...
April 1, 20232 yr comment_652015 In all seriousness, I would assume it's an air vent to let the ozone out? Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652015 Share on other sites More sharing options...
April 1, 20232 yr comment_652024 2 hours ago, Captain Obvious said: In all seriousness, I would assume it's an air vent to let the ozone out? Really?? Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652024 Share on other sites More sharing options...
April 1, 20232 yr comment_652031 There is stuff on the internet, of course. https://advancedstructures.in/starter-motor-teardown-and-feature-study/ Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652031 Share on other sites More sharing options...
April 1, 20232 yr comment_652032 More. Larry B can't be wrong...   Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652032 Share on other sites More sharing options...
April 2, 20232 yr comment_652058 9 hours ago, Patcon said: "In all seriousness, I would assume it's an air vent to let the ozone out?" Really?? Serious. The electrical arcing in the motor brushes creates ozone. Here's a snippet from wikipedia >> https://en.wikipedia.org/wiki/Ozone Incidental production: Ozone may be formed from O2 by electrical discharges. Unsuppressed arcing in electrical contacts, motor brushes, or mechanical switches breaks down the chemical bonds of the atmospheric oxygen surrounding the contacts. Certain electrical equipment generate significant levels of ozone. This is especially true of devices using high voltages, such as ionic air purifiers, laser printers, photocopiers, tasers and arc welders. Electric motors using brushes can generate ozone from repeated sparking inside the unit. Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652058 Share on other sites More sharing options...
April 2, 20232 yr comment_652062 Who'd a thunk it!! Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652062 Share on other sites More sharing options...
April 2, 20232 yr Author comment_652066 Thanks Zedhead for the info.. you gave ... on April 1st.. Link to comment https://www.classiczcars.com/forums/topic/68241-starter-with-some-extra-inoutlet-what-is-this/#findComment-652066 Share on other sites More sharing options...
