Recently Browsing 0
I thought I start a special thread on a recent development on my Z. Absolutely beautiful day today and perfect for driving the Z. Pulled it out of the garage and I noticed it was running very rough. It didn't really hit me until I tried to accelerate away from my house. Engine was weak, and running rough as if a cylinder was down. Hmmm....ran perfect last time I drove it. The only thing Ive don't since last drive was to pull the cold start injector and test it ton make sure it wasn't the cause of my running rich condition. I put it all back together as it was but when a problem developes its prudent to inspect the last item you touched.
So I drove back to the house and began going through each possibility one by one and I still cannot figure it out.
Checked:
1. Spark...strong on all wires. Got about a 1" spark from each plug wire.
2. Timing.. 11 Deg before TDC at idle
3. Full Pressure- 30 PSI at idle
4. Checked each injector with a screw driver, all were firing.
5. Extra Fuel filter I installed coming from tank is clear of debris
6. Pulled the valve cover off. Valve train looks normal. Checked valve lash, all were good.
7. Swapped to my backup E12 ignition unit and no change
8. Replaced the ECU
9. Checked for vacuum leaks, all looked normal
10. Checked Temp sending unit...unplugged and car died. Acting normal
what else could I be missing.
https://www.classiczcars.com/forums/topic/68273-rough-running-engine-with-no-explanation/Share on other sites
