AFM Sticky Spot
Captain Obvious
So @HusseinHolland, if there is no silicone blob, one other trick I've used is there might be a dent/divot on the gear where the clamp was tightened. If you look at the clamp, you'll see the dot pressed into it. That dot can leave an impression in the gear plastic as well.
Kinda tough to tell... Your's might be fine, or might not. I'm sure that helps a whole lot, right?  LOL
LOL - I'll have to take a closer look. I'm going to drive it around for a couple days, it still needs all the rear work, but it feels pretty good now that the front end isn't floating all over the road.
  • Who's Online   2 Members, 0 Anonymous, 707 Guests (See full list)
