Posted May 13, 20231 yr comment_653604 So I am messing around with heater boxes right now and I was pressure testing two heater valves I had. I cobbled together some hoses to attach my coolant tester to. One valve did ok, although it leaks slightly around the push rod when it's being actuated. The other leaks badly as the junction of the brass body to the steel bracketry. So in the best Captain Obvious manner, I decided to take it apart! Folded the ears back and removed the bracketry The internals just pull out after that There is a square O ring seal between the hard plastic end and an inner washer. I think if it were replaced the valve would seal up. I've started looking for suitable O rings without having to buy a 100qty. Bead blasted the valve body just for fun Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/ Share on other sites More sharing options...
May 14, 20231 yr comment_653616 Once upon a time (fifteen years ago), there was a generic rebuild kit available from NAPA that provided the necessary seals. When I checked circa 2015, it was NLA. Napa part #660-1000 Good hunting. Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653616 Share on other sites More sharing options...
May 14, 20231 yr Author comment_653621 Cool! Have to try that! Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653621 Share on other sites More sharing options...
May 14, 20231 yr Author comment_653622 They're using that number but I don't think it's the same part https://www.napaonline.com/en/p/BK_6601000 Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653622 Share on other sites More sharing options...
May 14, 20231 yr comment_653626 Here's the article that referenced the NAPA kit. Created by 'Palladin' and uploaded to the Zcar.com website many years ago. 280ZX Heater Cock Rebuild (auto-cock, pull type).pdf Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653626 Share on other sites More sharing options...
May 14, 20231 yr Author comment_653632 3 hours ago, Namerow said: Here's the article that referenced the NAPA kit. Created by 'Palladin' and uploaded to the Zcar.com website many years ago. 280ZX Heater **** Rebuild (auto-****, pull type).pdf 481.96 kB · 0 downloads That is for a 280ZX. The heater parts look a little different. I wonder if it's possible to rebuild the older style valve with the newer parts? Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653632 Share on other sites More sharing options...
May 14, 20231 yr comment_653635 We'll know the answer to that question after you've located the NAPA kit.😄  I suspect that the internals didn't change over the design history of that valve. Base plate, levers, mounting holes, yes. But cylinder, cap, plunger, rod and seal --- less likely. Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653635 Share on other sites More sharing options...
May 15, 20231 yr comment_653653 Nice work! Always good to rebuild when possible. It's better to problem-solve & find a solution vs. just replace If you have a selection of AC orings, for example, the thick wall variety would probably seal, since it's just the seat, not the sliding seal. I doubt that square cut is an imperative, if one cannot be readily sourced.  Edited May 15, 20231 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653653 Share on other sites More sharing options...
May 15, 20231 yr Author comment_653658 7 hours ago, HusseinHolland said: Nice work! Always good to rebuild when possible. It's better to problem-solve & find a solution vs. just replace If you have a selection of AC orings, for example, the thick wall variety would probably seal, since it's just the seat, not the sliding seal. I doubt that square cut is an imperative, if one cannot be readily sourced.  I looked through my O-ring assortments. I didn't find one that looked like a good candidate yet. I'm gonna keep looking locally Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653658 Share on other sites More sharing options...
May 15, 20231 yr comment_653659 I'm with Hussein. There's a lot of pleasure taken from bringing a worn part back to life. I've repaired more switches, valves, contractors, etc. than I could ever count, and most have continued to operate for many years. Having a 3D printer helps! Nice work bead blasting. Did you do it wet or dry? It looks perfect. I once found a place that would sell you one oring. Amazing! or so I thought, then they add the shipping. Really? $15 to mail one oring? Buy the bag of a 100.🙄 Think of the business you could start repairing heater valves. Edited May 15, 20231 yr by ETI4K Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653659 Share on other sites More sharing options...
May 16, 20231 yr Author comment_653660 The $15, is to pay the guy to wander out into the warehouse, find it and then drop it in an envelope. I do agree it seems excessive but it might not be... Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653660 Share on other sites More sharing options...
May 16, 20231 yr comment_653665 The internal part with the rubber parts is a perfect test .. put it in washing detergent and let it soak a few days (heat it up sometimes to max 60 C. you get new rings.. (only if the rings are not damaged ofcourse) Link to comment https://www.classiczcars.com/forums/topic/68337-heater-valve/#findComment-653665 Share on other sites More sharing options...
