Changing auto transmissions
Don McNabb
Can I change my 240z (1972) AT with a 4 speed AT from I think a Datsun Maximum. I was told the drive train is the same and that the two drive trains are the same except the 240 is a 3 speed and the Maximum is a 4 speed. Or is this a dumb idea
Why not upgrade to a manual?
  • Agree 1
Do you have the torque converter to go with the 4N71 transmission? Otherwise the OD gear won't work right. Also, there are two versions. L4N71B has a regular torque converter, and the E4N71B has an electronic torque converter. I'm not sure which one came on the Maxima, but the E4N71B version should have some wiring to make it work.
A little more searching suggests that if it's a Maxima transmission, it's the L4N71B.
Edited by SteveJ
  • Who's Online   1 Member, 0 Anonymous, 737 Guests (See full list)
