SteveJ Posted May 23, 2023 Share #13 Posted May 23, 2023 5 minutes ago, Zed Head said: Most Ford vehicles have inertia switches. If you want a high volume auto factory made piece. No offense to the Amazon parts but I'd rather have a used (by time only) Ford part than an untested part. Typically behind the kick panel on the passenger side. The red button is visible so that it can be reset. Salvage yards would have hundreds. But I have tested it, just not in an accident. Link to comment Share on other sites More sharing options...
Zed Head Posted May 23, 2023 Share #14 Posted May 23, 2023 I'm just saying, Ford parts probably don't get these kinds of reviews. Amazon is full of cheap parts. I have a set of headphones that broke after a year and Amazon just "disappeared" them and the company that sold them from their web site. From the United States DGC 1.0 out of 5 stars It stopped working Reviewed in the United States 🇺🇸 on July 15, 2022 Verified Purchase This was the cheapest option and I should have spent more money. It doesnt necessarily feel bad initially. I tested it a few times and it worked like I wanted. I went to install this and of course it wouldnt reset anymore. Look elsewhere for a product Helpful Report david chappell 1.0 out of 5 stars Cheap quality Reviewed in the United States 🇺🇸 on October 26, 2022 Verified Purchase Broke immediately after install Helpful Report Joy V Pawless 1.0 out of 5 stars connector will not secure Reviewed in the United States 🇺🇸 on August 10, 2022 Verified Purchase The connector that plugs into the switch doesn't secure or lock in. I just trashed it. Helpful Report bobsled 46 1.0 out of 5 stars Very trigger happy Reviewed in the United States 🇺🇸 on July 17, 2022 Verified Purchase Mine tripped when I closed the car door. And I tried 2 of them. Buy something else Link to comment Share on other sites More sharing options...
SteveJ Posted May 24, 2023 Share #15 Posted May 24, 2023 Nice cherry-picking there. Link to comment Share on other sites More sharing options...
Zed Head Posted May 24, 2023 Share #16 Posted May 24, 2023 All of the ratings are shown. If you pick 4 and 5 as "good" and 3 or lower as "bad", you get a 70% good rate. Who wants that? Ford has produced millions of them. Not really seeing anything to argue about. Are you still going to use it? Imagine hitting a bump while driving and having the engine die. The safety device actually causes an unsafe condition. Sorry it had to be you. It's not personal... Link to comment Share on other sites More sharing options...
conedodger Posted June 11, 2023 Share #17 Posted June 11, 2023 On 5/22/2023 at 5:35 PM, Zed Head said: Your 77 should already have one in the AFM. When air flow stops the fuel pump power is cut off. Your fuel pump should not be running when you turn the key on. Only at Start and when the engine is running. That first picture shows a modified engine, with individual coils. It must have aftermarket engine management. But, on the topic, if you haven't already done it - the 1978 and 280ZX fuel rails are safer than the three piece 75-77 rails. The hose connecting the three pieces can leak. That first picture shows what's probably a 78 rail. One piece metal. I think the fuel shut off in the 77 was actually an orientation thing. If the car was upside down, the fuel was shut off. Porsche’s burn down a lot more often I think. Particularly carburetor models. personally, I don’t think the 280Z system is that vulnerable to fire as in a perfect world, which you should maintain, it’s a closed system with no fuel exposure. You’re more likely to have an electrical fire. 1 Link to comment Share on other sites More sharing options...
Zed Head Posted June 11, 2023 Share #18 Posted June 11, 2023 Here's Nissan's view. Link to comment Share on other sites More sharing options...
Zed Head Posted June 11, 2023 Share #19 Posted June 11, 2023 More - Link to comment Share on other sites More sharing options...
Zed Head Posted June 11, 2023 Share #20 Posted June 11, 2023 (edited) Just as vague in 1978. "engine accidentally stops while driving". ??? Edited June 11, 2023 by Zed Head Link to comment Share on other sites More sharing options...
