Recently Browsing 0
I'm working on getting the old dry-rotted cracked leaky hoses off some fuel injectors.
In the past, I've simply cut/pulled/snipped/pried the old hose off the injectors, and while that works, it's always resulted in some scratching to the barbs on the ends of the injectors. The FSM talks about grinding the hoses off and I'd like to give that a try. Problem is, grinding could destroy the small metal ferrules at the base of the hose.
So, question is... Anyone have a source for replacement ferrules?
Here's a pic of injectors with and without the hose. I used the old standby method to get that hose off (in pieces), and I'm looking for a better option. Before and after the cutting/slicing approach to hose removal:
If I destroy these ferrules, are replacements available? Note that you can see some scratching on the hose barbs from the removal process:
https://www.classiczcars.com/forums/topic/68354-getting-old-hoses-off-barbed-fuel-injectors/Share on other sites
