73str86 Posted August 12, 2023 Author Share #37 Posted August 12, 2023 2 Link to comment Share on other sites More sharing options...
Popular Post zclocks Posted August 12, 2023 Popular Post Share #38 Posted August 12, 2023 You have to love the car and be willing to spend the $$ to bring it back for a second life. I think the key is what 87jm said about his experience with a very poor resto shop. I've been there and spent big dollars and years trying to correct what a certain So Calif shop did to my 280z. The real take away is find someone who has used a particular resto shop, is very satisfied, and use them. A good shop that loves Datsuns is worth everything. I hope you restore your car or sell it to someone who has the resources to restore it correctly. Good luck 3 2 Link to comment Share on other sites More sharing options...
73str86 Posted August 20, 2023 Author Share #39 Posted August 20, 2023 I tried busting a couple dry rusty lug nuts with a tire iron last weekend, and failed. I'm going to keep the wheels and hub caps. I sprayed the lugs/studs with Kroil earlier today and picked up a cheap electric impact gun because I can't find my cordless Milwaukee during the move. If I am successful, she will be listed on ebay with the bead blasted slotted Shelby mags and new tires. 1 Link to comment Share on other sites More sharing options...
73str86 Posted August 20, 2023 Author Share #40 Posted August 20, 2023 I wish I had my milwaukee rated for 1400 ft lbs. This $45 Chicago Electric is rated at less than 250 ft lbs. I successfully mounted the front wheels, but the cheap impact literally shook itself apart on the rear lug nuts and didn't break a single one loose. I added another application of Kroil to the rear lug nuts. I'm going to return the impact gun tomorrow and buy the next level Bauer, rated for 400+ ft lbs. Link to comment Share on other sites More sharing options...
73str86 Posted August 20, 2023 Author Share #41 Posted August 20, 2023 1 Link to comment Share on other sites More sharing options...
AK260 Posted August 21, 2023 Share #42 Posted August 21, 2023 If that was an air cooled 911 or a 356, you are looking at $20-25K as it sits. But 240Z. A parts car. IMO.To your point - this thing was literally paper thin in areas - probably why the do not touch sign was on it - and I was shocked how much it sold for 6 year ago!! But never underestimate the power of of having will and skill! If the OP can do metalwork to a high standard then a tonne of cost is saved. 1 1 Link to comment Share on other sites More sharing options...
73str86 Posted August 26, 2023 Author Share #43 Posted August 26, 2023 Going on ebay soon. Link to comment Share on other sites More sharing options...
73str86 Posted August 29, 2023 Author Share #44 Posted August 29, 2023 Link to comment Share on other sites More sharing options...
87mj Posted August 29, 2023 Share #45 Posted August 29, 2023 I must admit that is an odd car. Looking at the outside, I see a lot of sheet metal that needs repaired. All doable. But when I look at the engine bay and all of those rusted bolts, rusted fuel rail, etc, I wonder how many bolts will snap in the engine and the suspension during tear down. When I see the engine, the body sheet metal doesnt reflect how wet the car has been. Link to comment Share on other sites More sharing options...
Yarb Posted August 29, 2023 Share #46 Posted August 29, 2023 Possibility it got flooded somewhere In its life time. Maybe salt water. Wonder what the inside sheet metal looks like. 2 Link to comment Share on other sites More sharing options...
Zed Head Posted August 29, 2023 Share #47 Posted August 29, 2023 You'll do better with more pictures. The door jamb tag and the fenderwell tag and the firewall VIN stamp and more of underneath. Also some side-on views from a lower angle. Those rockers look rusty. Floor pans too. And interior. Anyone looking to restore a low number car will want to know how bad the rust is. I'd guess that Indiana uses salt on the roads and that that car saw some salt. Good luck. Post the listing when it's up. Link to comment Share on other sites More sharing options...
bartsscooterservice Posted August 30, 2023 Share #48 Posted August 30, 2023 15 hours ago, 87mj said: I must admit that is an odd car. Looking at the outside, I see a lot of sheet metal that needs repaired. All doable. But when I look at the engine bay and all of those rusted bolts, rusted fuel rail, etc, I wonder how many bolts will snap in the engine and the suspension during tear down. When I see the engine, the body sheet metal doesnt reflect how wet the car has been. wd40 bath first 1 1 Link to comment Share on other sites More sharing options...
