Well not a moment too soon for the bearings, at least they did their job and sacrificed themselves because the crank journals aren't that bad.  I'll still send the crank out for polishing.
Because the engine has been sitting for so long I gave each shell a couple of swipes with a scotch pad to bring out how much much copper is showing, these could have spun any moment.  First pic is the rod bearings, second are the mains.
The crank is showing some water marks and some copper transfer.
Knocked out the freeze plugs and found lots of crud and silicone sealer clogging up passages.
Pretty sure the marks on the combustion chamber and piston are mechanical damage caused by a foreign object. It could have been a spark plug electrode that broke off, or something ingested through the intake.
I’ve seen both mechanical damage from foreign objects, and detonation damage which will have severe burn marks where the piston and/or combustion chamber begin to melt accompanied by mechanical damage such as broken ring lands and broken rings.
This hemi ate a valve during a pass. There was damage in every combustion chamber. There were bits of broken and twisted metal in the intake and carburetor throats.
Edited by Racer X
7 hours ago, Patcon said:
Yeah, those bearings weren't long for this world...
But even with all the trash that scored up the bearings, the oil pump is in very nice shape. As far as I can tell, the engine has seen light use but a lot of neglect, I'll bet most of that wear happened on startup with old dirty oil. I rolled the block outside yesterday, removed the plug sealing the main oil passage and scrubbed every hole with bottle brushes, lots of oil sludge in those lines.
💡 Could have been an obstruction in the line leading to oil starvation!
55 minutes ago, zclocks said:
Question. How did you remove the broken stud?
Ron
The second pic down I've welded a blob on top of the broken stud, 3rd pic I rest a nut on top of the blob and weld those together, quench it with WD40 and unscrew it.
Most of the work is done by the heat.
