June 28, 20231 yr Author comment_654581 Thank you for taking the time out of your day for doing this, I appreciate it. Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654581 Share on other sites More sharing options...
June 28, 20231 yr comment_654586 @Mike Thoughts on creating a knowledge / resource base area for 3d printer files? So they dont get buried in Individual threads Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654586 Share on other sites More sharing options...
June 28, 20231 yr comment_654603 On 6/28/2023 at 1:55 AM, Patcon said: @Mike Thoughts on creating a knowledge / resource base area for 3d printer files? So they dont get buried in Individual threads I think that's a great idea... Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654603 Share on other sites More sharing options...
June 28, 20231 yr comment_654607 First attempt! A little stringing, but I think that most of it will clean up with a little Exacto knife trimming. I will try to tweak the settings , and print again tonight. Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654607 Share on other sites More sharing options...
June 28, 20231 yr comment_654608 On 6/27/2023 at 9:47 PM, ckurtz2 said: I often made small intricate parts, was hard to tell they were even 3D printed. However, the printers I used were like $40,000 plus each. Yeah, I probably should have prefaced my post with "In my limited, ancient experience...." Haha! So hope the parts work out and whether they are good enough or not, I find the fact that the people here are willing to jump up and try to help out by making parts i fantastic. One of the reasons this is the best forum! Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654608 Share on other sites More sharing options...
June 28, 20231 yr Author comment_654611 @crayZlair Thanks! Not to bad at all for the first try, maybe slow down the print speed and decrease nozzle temp to prevent oozing? It has been a very long time since I've played with a single filament printer, so you probably know better than me. @Captain Obvious I agree 100% I have been using this forum for years, and its always been a great atmosphere. Let me know if those tabs work well. Put them through the ringer and see how strong they are. Anyways, to finish designing the other connector as well as really perfect the dimensions on this part I need to remove the wires from the connector. Does anyone have a tried and true tool they bought to depress the two prongs that hold in the wire to the connector? I am tired of stabbing myself with a dental pick haha. Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654611 Share on other sites More sharing options...
June 28, 20231 yr comment_654612 On 6/28/2023 at 4:38 PM, ckurtz2 said: @crayZlair Thanks! Not to bad at all for the first try, maybe slow down the print speed and decrease nozzle temp to prevent oozing? It has been a very long time since I've played with a single filament printer, so you probably know better than me. @Captain Obvious I agree 100% I have been using this forum for years, and its always been a great atmosphere. Let me know if those tabs work well. Put them through the ringer and see how strong they are. Anyways, to finish designing the other connector as well as really perfect the dimensions on this part I need to remove the wires from the connector. Does anyone have a tried and true tool they bought to depress the two prongs that hold in the wire to the connector? I am tired of stabbing myself with a dental pick haha. Look at reply 17 - https://www.zcar.com/threads/transistor-ignition-unit.424466/#post-2798228 Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654612 Share on other sites More sharing options...
June 28, 20231 yr comment_654623 On 6/28/2023 at 4:38 PM, ckurtz2 said: Let me know if those tabs work well. Put them through the ringer and see how strong they are. My second attempt didn't turn out much better than the first. As for the tabs, I compressed them, and they immediately snapped. I measured them at 1.5mm thick, is this correct? Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654623 Share on other sites More sharing options...
June 29, 20231 yr Author comment_654626 I will have to double check my measurements when I get home, but yes that sounds about right. Most of the plastic is super thin on the connector. Out of curiosity what material are you printing with? I think PBT is what normal automotive manufactures use for connectors but I forget. That is really depressing to hear about the tabs, nothing good comes easily though. Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654626 Share on other sites More sharing options...
June 29, 20231 yr comment_654627 I am using E-Sun brand PLA+ That's all I have. I am going to try a different orientation of the part, so that the "grain" goes with the height of the tab instead of the width. Edited June 29, 20231 yr by crayZlair added text for clarity Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654627 Share on other sites More sharing options...
June 29, 20231 yr comment_654631 Success! The orientation along with a general support instead of tree support seemed to do the trick. No Exacto trimming needed. @ckurtz2 message me your mailing address and I will send it to you. Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654631 Share on other sites More sharing options...
June 29, 20231 yr Author comment_654632 Looks incredible, I PM'd you the address and some questions. Thank you! Link to comment https://www.classiczcars.com/forums/topic/68410-1977-280z-dash-harness-connectors/?&page=2#findComment-654632 Share on other sites More sharing options...
