Posted July 4, 20231 yr comment_654808 I have a 6/71 which should have the earlier harness with the longer pig tail fuse box connections. Seems the PO mixed and matched some stuff from a 72 or later and I think I have a late 71 / 72 dash harness and short pig tail fuse box. As I start on the dash area restoral couple of questions if you don't mind. First, are there any major differences with the harness I need to worry about or as long as the fuse box matches the harness I should be good? Everything seemed to be working off dash / console except the radio and rear defrost but I know why. The rear defrost had the inline fuse holder broken (needs replacing) and the radio was something he just threw in there. I have an original seek AM I'm going to try and get to work (supposedly it does) and it seems to match up with all the connectors. As I trace everything though it seems there are a few things unconnected if someone can identify these please What's this blue/red connector on the heater panel section? And this blue bullet connector maybe is power to the optional air conditioner? And this green / black connector coming off the rear defrost line? Maybe the optional door lights? Any help appreciated. Link to comment https://www.classiczcars.com/forums/topic/68431-early-71-vs-late-71-dash-harness/ Share on other sites More sharing options...
July 4, 20231 yr Author comment_654845 16 hours ago, Richie G said: And this green / black connector coming off the rear defrost line? Maybe the optional door lights? Could this green / black be the seat belt lights in the later consoles? Makes sense since it's located with the rear defrost switch wiring. That could mean these two are the power for the ac switch and the power for the door lights maybe? 16 hours ago, Richie G said: What's this blue/red connector on the heater panel section? And this blue bullet connector maybe is power to the optional air conditioner? Link to comment https://www.classiczcars.com/forums/topic/68431-early-71-vs-late-71-dash-harness/#findComment-654845 Share on other sites More sharing options...
