Posted July 13, 20231 yr Popular Post comment_655093 Since I had to cut off the exhaust to deal with all the rear suspension work, I decided to put together a 3" SS rear section, starting after the existing cat, then going to a 2.5" Stainless Works rear muffler (ran it on my X1/9 K24 swap for a few months). The 3" SS exhaust I put together  from a exhaust I had made years ago for my Volvo C30, before I converted it to AWD & had to make it all over again. Forgot to take pic before I cut it up - this is what it was Eyeball the general placement, then cut, & tape together to check clearance off the forward crossmember and lower control pivot & diff casing tack welded, then recheck fit I'll be adding a 3" - 2.5" step from this into the muffler looks pretty good step down & dogleg to attach to existing exhaust/cat. I'll rework the entire exhaust forward of the 2 bolt 3" flange when I do the VQ35DE 2"-2.5" - 2.5"- 3" steps  Edited July 14, 20231 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/ Share on other sites More sharing options...
July 15, 20231 yr comment_655103 What welding setup are you using? MIG? Stick? Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655103 Share on other sites More sharing options...
July 15, 20231 yr Author comment_655104 9 minutes ago, Racer X said: What welding setup are you using? MIG? Stick? TIG for this  - it's all stainless. I could use my MIG I suppose, but I don't have stainless wire for it. TIG is cleaner for pipe anyway. Where I had good butt-joins, the welds are clean (enough, I'm not a professional). Where there was discrepancy/offset, so so much. More work on the exhaust today. Got all the tacked seams welded, and figured out the muffler placement cut down the 3"-2.5" step for the available spacing have to figure out the hanger here, have to make sure it pulls it slightly away from the spare well like this maybe or here, to push it away from the spare well. There is a hole in each corner of the gas tank, I could use this one, and add a smaller outward placed one to locate the strap from potential rotation maybe one set here Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655104 Share on other sites More sharing options...
July 16, 20231 yr Author comment_655127 Made a bracket (from a Volvo dash support) to utilize the stock hanger point at the front end of the muffler reinforced to make sure it can't flex. The lip at the top tucks over the frame bracket muffler hanger attachment in place. Drilled an inboard hole in the stock welded bracket to positively locate the new bracket. With that figured out, I tack welded the hanger to the muffler Removed & finished the seam welds for the muffler inlet & tailpipe section. Just have to weld on the Redtail exhaust tip when it gets here. Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655127 Share on other sites More sharing options...
July 17, 20231 yr Author comment_655156 Change of plans - I removed the front pipe. One of the Datsun guys on Turbobricks said the 2-1 junction is a severe choke point. His solution was to make a new 2-1 section in 2" pipe I can't weld something like that, Dealing with welding those to the flange, and the collector are extremely awkward, from my experience with the first header on the K24, I'm not willing to risk it. Stock front pipe. Flange. Making 2" pipes fit the flange would be tricky. I thought about using a 1 7/8" holesaw to get it close, then grinder to get the rest. I don't have a spare DP, so just not worth it. taper point, only about 1.5" ID in there So, I cut off the upper section of the DP where it's approx 3" wide & modded another section of my old C30 3" exhaust to fit. after a bunch of back & forth, I tacked it here. To minimize the reduction in the stock collector I cut it so there is only about 1/8" tuck. test fit - clears the heat shield (next to my finger) by the same amount as the stock pipe - just looks like there's no clearance It was raining at this point, so I took it down & seam welded the joint. But.. it moved, so I had to cut the pipe & add a pie cut (to be welded later) to get the pipe pointed where it needed to go New cat & used resonator from a Volvo S40 T5. Edited July 20, 20231 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655156 Share on other sites More sharing options...
July 19, 20231 yr Author comment_655210 Got the rest of the front section figured out. No room for the 3" resonator though. Added a dogleg to get good alignment with the rest of the front section added a straight section off that, into a 3" cat, then another 10" section into the mid connection good clearance all around fitted the cat behind that 10" section between cat & dogleg into 3" flange removed again to tack rear mid section re-installed one more time to figure out the hanger off the transmission case, then removed. Now I have to seam weld all the junctions  Edited July 19, 20231 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655210 Share on other sites More sharing options...
July 20, 20231 yr Author Popular Post comment_655231 Welded up all the seams, took almost 4 hours(!) After that, I had to reinstall it to figure out the center mount. I decided to make one that used the stock mounting points Once I had that figured out, I tacked it in place & then removed the entire exhaust to finish the mount welds for this & the rear muffler hanger Archie was hanging around me much of the day I had forgotten about the trans mount / carrier bushings, so I did those now put the exhaust back in (hopefully for the last time) clearances still good Hangers Still waiting for the Redtail Performance tailpipe 😞  Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655231 Share on other sites More sharing options...
July 28, 20231 yr Author comment_655438 RedTail Perf. Exhaust tip finally arrived. Nicely constructed pieces. This particular transaction with the company was a PITA though. Anyway, to question would be how much to have it protrude relative to the skinny bumper install. Didn't have much luck finding pics online to refer to. I can cut a couple inches off the tailpipe & set it like this: Â Â Edited July 28, 20231 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655438 Share on other sites More sharing options...
July 29, 20231 yr Author comment_655466 Expanded the tailpipe to get a tight fit for the tip, set it close to the bumper depth, to hopefully avoid exhaust discoloration of the taillamp  Edited July 29, 20231 yr by HusseinHolland Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655466 Share on other sites More sharing options...
July 29, 20231 yr Author comment_655469 Youtube of exhaust note, during warmup  Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655469 Share on other sites More sharing options...
August 2, 20231 yr Author comment_655594 So, now that I'm driving it again, the exhaust is WAAAAYYYY to loud & drones terribly between 2-3K rpm. I will have to look at a different muffler, and perhaps a resonator that is smaller than the 3" Magnaflow I have, that was too long to fit after the cat in the straight section, which is only about 10". Â Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655594 Share on other sites More sharing options...
August 3, 20231 yr Author comment_655617 3" OD, 9" long resonator came today, so I'll hopefully get that in tomorrow. Â In the middle of making bike carrier adapters to hold the Volvo/Thule load bars & bike carriers I have had since the early 90's. I added stake holders to the bed sides when I made the truck. When my kids were young, we would typically fit 4 bikes on the roof of whatever Volvo wagon I had at the time. Wife & I are going to go upstate NY & CT in a couple weeks to do some hiking & rail trail biking. my bike is almost as old as my pickup. Link to comment https://www.classiczcars.com/forums/topic/68448-3-exhaust-cat-back-prep-for-vq35de-conversion/#findComment-655617 Share on other sites More sharing options...
