3" Exhaust, cat-back. Prep for VQ35DE conversion
HusseinHolland
9 minutes ago, Racer X said:
What welding setup are you using? MIG? Stick?
TIG for this  - it's all stainless. I could use my MIG I suppose, but I don't have stainless wire for it. TIG is cleaner for pipe anyway. Where I had good butt-joins, the welds are clean (enough, I'm not a professional). Where there was discrepancy/offset, so so much.
More work on the exhaust today. Got all the tacked seams welded, and figured out the muffler placement
cut down the 3"-2.5" step for the available spacing
have to figure out the hanger here, have to make sure it pulls it slightly away from the spare well
like this maybe
or here, to push it away from the spare well. There is a hole in each corner of the gas tank, I could use this one, and add a smaller outward placed one to locate the strap from potential rotation
maybe one set here
  • Like 3
Made a bracket (from a Volvo dash support) to utilize the stock hanger point at the front end of the muffler
reinforced to make sure it can't flex. The lip at the top tucks over the frame bracket
muffler hanger attachment
in place. Drilled an inboard hole in the stock welded bracket to positively locate the new bracket.
With that figured out, I tack welded the hanger to the muffler
Removed & finished the seam welds for the muffler inlet & tailpipe section. Just have to weld on the Redtail exhaust tip when it gets here.
  • Like 3
Change of plans - I removed the front pipe. One of the Datsun guys on Turbobricks said the 2-1 junction is a severe choke point.
His solution was to make a new 2-1 section in 2" pipe
I can't weld something like that, Dealing with welding those to the flange, and the collector are extremely awkward, from my experience with the first header on the K24, I'm not willing to risk it.
Stock front pipe.
Flange. Making 2" pipes fit the flange would be tricky. I thought about using a 1 7/8" holesaw to get it close, then grinder to get the rest. I don't have a spare DP, so just not worth it.
taper point, only about 1.5" ID in there
So, I cut off the upper section of the DP where it's approx 3" wide & modded another section of my old C30 3" exhaust to fit. after a bunch of back & forth, I tacked it here. To minimize the reduction in the stock collector I cut it so there is only about 1/8" tuck.
test fit - clears the heat shield (next to my finger) by the same amount as the stock pipe - just looks like there's no clearance
It was raining at this point, so I took it down & seam welded the joint. But.. it moved, so I had to cut the pipe & add a pie cut (to be welded later) to get the pipe pointed where it needed to go
New cat & used resonator from a Volvo S40 T5.
Edited by HusseinHolland
Got the rest of the front section figured out. No room for the 3" resonator though.
Added a dogleg to get good alignment with the rest of the front section
added a straight section off that, into a 3" cat, then another 10" section into the mid connection
good clearance all around
fitted the cat behind that
10" section between cat & dogleg into 3" flange
removed again to tack rear mid section
re-installed one more time to figure out the hanger off the transmission case, then removed. Now I have to seam weld all the junctions
  • Like 4
RedTail Perf. Exhaust tip finally arrived.
Nicely constructed pieces. This particular transaction with the company was a PITA though.
Anyway, to question would be how much to have it protrude relative to the skinny bumper install. Didn't have much luck finding pics online to refer to.
I can cut a couple inches off the tailpipe & set it like this:
So, now that I'm driving it again, the exhaust is WAAAAYYYY to loud & drones terribly between 2-3K rpm. I will have to look at a different muffler, and perhaps a resonator that is smaller than the 3" Magnaflow I have, that was too long to fit after the cat in the straight section, which is only about 10".
  • Like 4
3" OD, 9" long resonator came today, so I'll hopefully get that in tomorrow.
In the middle of making bike carrier adapters to hold the Volvo/Thule load bars & bike carriers I have had since the early 90's. I added stake holders to the bed sides when I made the truck. When my kids were young, we would typically fit 4 bikes on the roof of whatever Volvo wagon I had at the time. Wife & I are going to go upstate NY & CT in a couple weeks to do some hiking & rail trail biking. my bike is almost as old as my pickup.
  • Like 3
