23 hours ago, dylancorrea1 said:
godzilla race works rail that comes with a built in gauge. But after doing some price calculations I’m looking at around 380-400 in total price.
That seems like a lot.  There's really no need for a gauge, unless you plan to change fuel pressure often.  Once you set it it doesn't change.
Looks like they're charging $30 - 40 just to drill and tap a hole.  If you're handy you can do that yourself.
https://www.godzillaraceworks.com/fuel/pallnet-billet-aluminum-fuel-rail
I can definitely make that rail myself, I saw the last thread on making one. I think the rail is definitely an inflated item.
I made one from some inexpensive blemished bar stock.  It wasn't too hard.  I had a drill press and built a jig to hold the bar.
I think it might have been from here.  Still out there.
Edit - not sure if one foot is enough though.  The eBay listing reads like you can only get one foot sections.  Can't remember.  Probably in site's thread.
https://www.ebay.com/itm/204109661735?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=Pm6JCi7cTr6&sssrc=2047675&ssuid=bBzFtXzvTQO&widget_ver=artemis&media=COPY
Edited by Zed Head
It's definitely a real-time reference.
Once I got my Z problems all sorted out I barely opened the hood more than once a month.  And that was only to check the oil and coolant reservoir.  So, it really depends on where you're at in your project.  I also had found a Schrader valve T'ed in to an Isuzu fuel line in the wrecking yard.  So I had a Schrader valve for measuring pressure easily.  Many different ways to do things.  You can probably find electronic methods today and have a gauge in the car.
I remember looking for one of these  in a junk yard and finding one. I balked when they called it a "fuel rail" and wanted a bunch of money for it. They were used on the Rodeo SUV IIRC. Do you remember what year range these came from?  I can't find the info on it any longer.
You could get a tee like what @Patcon linked and buy a schraeder valve to go into it. https://www.summitracing.com/parts/ear-9616sverl or https://www.amazon.com/Earls-9616SVERL-Male-Schrader-Valve/dp/B01EKUFV90
Edited by SteveJ
The Isuzu valve was nice because it was all one piece and the metal tube is 5/16" / 8 mm.  cut the tube and slide it in.  I posted a picture in a previous thread.
I can't remember the year, I think it was late 80's.  Unfortunately, not really common to find them in the yards.
I was browsing pictures of a new BaT Z and found what looks like an FPR that holds pressure.  Might be worth some research.  Picture 114.
https://www.nengun.com/oil-fuel-fuel-pressure-regulators/
https://bringatrailer.com/listing/1972-datsun-240z-290/
