Wiper rebuild
Patcon
I have 3 sets of wiper mechanisms on the bench. I finally decided I would rebuild them and plate them since I have some other items that need to go to the platers. Since I didn't know of a comprehensive rebuild thread on CZC I thought I would make one
I did the break down today
So you need to be sure on reasssembly that it looks like this or you're gonna have problems!!
20230910_120650_resized.jpg20230910_120651_resized.jpg20230910_120656_resized.jpg20230910_120659_resized.jpg
I started on the single pivot end
The little clips aren't spring steel. The bend open. I might go back with snap rings on reassembly
Then the felt. I am working on replacements for these
Also shows the rubber seal that is on the face of the wiper pivot base
On the wiper side of the pivot there is a tiny spring steel ring. Like a little bull ring. I need to find a source for these. Some of them were rusted away
When you pull the wiper spindle out of the base there is a wavy washer at the bottom to prevent wear
  • Like 3
This is what the single side spindle looks like
This is the drive end of the linkage
Order of the top pieces
Be careful when disassembling this! There is a spring under here and the first one I did the spring and washer went flying. :blink:
Order of the lower pieces
Another pivot
Some of the later mechanism had some different parts
This mechanism has a rubber boot on the end of it. I believe Steve Nixon offers this part as a reproduction
20230910_123950_resized.jpg20230910_123952_resized.jpg20230910_123956_resized.jpg20230910_124018_resized.jpg20230910_124020_resized.jpg
Here is it half disassembled
20230910_124218_resized.jpg20230910_124221_resized.jpg20230910_124238_resized.jpg20230910_124240_resized.jpg
Out of the 3 mechanisms only had the spring in this orientation, but I beleive this is the correct position
The last one also had this little piece of plastic? I'm not sure of it's purpose
Some of the spindles were bound up in the bases, but we managed to get them all out
Now for the questions...
How do we think these were made??
20230910_141454_resized.jpg20230910_141457_resized.jpg20230910_141501_resized.jpg20230910_141818_resized.jpg20230910_141825_resized.jpg
I'm thinking the main body was yellow zinc by the looks of it, but the pivots almost look like they are hard chromed (??) then riveted through the main body? The drive pivot was tacked welded to prevent rotation maybe...
Thoughts? I have some that are badly corroded. What do you do then? Clean and yellow zinc?
@Captain Obvious@grannyknot
7 hours ago, Captain Obvious said:
Are you looking for input into how the pieces were machined and constructed, or input into details about the finish applied after construction?
Both, and recommendations on how to deal with them moving forward
Interessting as my 240z whipers are all over the place.. due to very worn mechanics i guess... so maybe there comes a time that i need your topic. Maybe there is a complete repair set for this? Also.. Have you looked for a complete whipers mechanic part in the orig nissan partslist? maybe you/we can buy it new?
22 hours ago, Patcon said:
That would be very surprising if they were available.
I would for sure check the partnumbers at Nissan
NISSAN made a promise many years ago to make all the sportscarparts available in the coming years.. so i heard.. i don't know if this IS THE CASE !!!!!!!!!!!
But i see the most strangest parts available again for the 240Z
ARE THERE PEOPLE HERE THAT HAVE SEEN THE SAME?  (Original 240z/nissan sportscar parts with the orig nissan/datsun partnumbers on it!)
I checked all of the part numbers listed for the wipers on carpartsmanual.com against courtesyparts.com. All that @Patcon might need are NLA.
  • Thanks 1
  • Who's Online   1 Member, 1 Anonymous, 830 Guests (See full list)
