I stumbled upon what is said to be a fan shroud for a 240z (well, S30) made by Sanden. Has anyone ever seen one of these? Any thoughts on whether it is meant for the shorter 240 radiator or the taller 280 radiator?
MSA has one similar if not exact but fiberglass. '70 thru '73. I would bet it's the shorter radiator.
I put a 280 radiator in my '72 with a full shroud off a junkyard ZX. Works great too. I have always wanted the scarce as hen's teeth 240 belly pan. One day I'll find one for a reasonable price.
https://www.thezstore.com/product/5386/radiator-shroud-70-73-240z
I’ll probably get the MSA one. This one is way too much. It’s also pretty different from the factory one. Other than being 3 pieces instead on one, it’s flat on the engine side. I was just curious if anyone had seen this before.
Yes. Good if you have parts to sell, bad if you want them.
I slightly blame MZR and other customizers. There are only so many of the NLA parts that aren’t being reproduced, and I will bet they hoarded stocked up on them.
Edited by Matthew Abate
