Hey, the turn signals in my 73 240z have been intermittent and I finally decided to bite the bullet and try and separate the turn signal assembly and I noticed that the little ball that's supposed to be on the end of the spring was missing. Basically #2 in this picture
Anyone have any idea what size that is? It might just guess and try and buy a few small ones
Picked up this set https://www.amazon.com/dp/B0BS95X63W?psc=1&ref=ppx_yo2ov_dt_b_product_details so I had a few sizes and the 3mm side was right on the money (and actually 3mm from my calipers).
Cleaned and tested everything else for proper contuinity, and using a little dialectric grease to hold the ball on the spring it went together pretty smoothly. Sorry about the slightly blurry picture.
Soldered a few of the top connections and good to go!
