October 22, 20231 yr comment_658432 Just posted on FB. Link to comment https://www.classiczcars.com/forums/topic/68559-240z-highlow-beam-switch-teardown/?&page=2#findComment-658432 Share on other sites More sharing options...
October 23, 20231 yr Author comment_658524 I managed to get it all reassembled and the switch is working ok. I was playing with it a bunch and maybe every 20-30 "toggles" the switch gets a bit jammed. Normally just pressing the switch again fixes it, but one time I had to take it out, manually push it, and then it was good again. In case anyone stumbles across this the spring I ended up choosing was "BB-31CS" (https://www.digikey.com/en/products/detail/century-spring-corp/BB-31CS/11671413) which is: OD - 0.105" (2.67mm) Length - 0.280" (7.11mm) Spring rate - 0.86 lbs/in Terrapin. I'll shoot you a message because having a backup would be good anyway Link to comment https://www.classiczcars.com/forums/topic/68559-240z-highlow-beam-switch-teardown/?&page=2#findComment-658524 Share on other sites More sharing options...
October 23, 20231 yr comment_658525 Probably going to have to contact the guy on FB market Place directly. Link to comment https://www.classiczcars.com/forums/topic/68559-240z-highlow-beam-switch-teardown/?&page=2#findComment-658525 Share on other sites More sharing options...
October 23, 20231 yr Author comment_658529 Oh shoot I misread Terrapins post. I'll reach out to them on FB Link to comment https://www.classiczcars.com/forums/topic/68559-240z-highlow-beam-switch-teardown/?&page=2#findComment-658529 Share on other sites More sharing options...
October 23, 20231 yr comment_658533 Yeah Harold is the guy with the parts. hopefully he still has it. It sounded like just what you were after and a decent price too. Link to comment https://www.classiczcars.com/forums/topic/68559-240z-highlow-beam-switch-teardown/?&page=2#findComment-658533 Share on other sites More sharing options...
