What is Everyone Doing for a Fuel Pressure Regulator?
the_tool_man
Fuel pressure regulators for these cars are getting harder to find.  The '77 and earlier EFI cars use a different design, with two regulated fuel inlets, that remains somewhat available.  But I can't find the single-inlet version for the '78-83 cars anywhere.  I'm looking because I'm considering an aftermarket fuel rail for my '77, which would eliminate the need for the dual-inlet type.  The usual sources I'm familiar with are out of stock for the later FPR.  Some owners have retrofitted aftermarket adjustable FPRs.  But only a couple use vacuum reference like OEM.  Also, most aftermarket FPRs only go down to 3.0 bar (OEM are 2.5 bar).  And they leak down during shutoff, making starting prolonged and aggravating.  I figure you '78 and ZX guys would have seen this sooner, and may have found a fix.  TIA.
Edited by the_tool_man
Corrected "outlet" to "inlet"
@HusseinHolland had some posts about the same problem.  In the past I had modified an adjustable regulator to be vacuum modulated.  Made me get on to Rockauto and look around.  VW's Super Beetles had 2.5 bar EFI in the seventies.  The FPR's are cheaper than the Nissan versions.  Should be able to make it work.
https://www.rockauto.com/en/catalog/volkswagen,1978,super+beetle,1.6l+h4,1423178,fuel+&+air,fuel+injection+pressure+regulator,6124
Thanks Zed Head.  That part number looks promising.  And it seems to be widely available, too.
I'd read your thread about alternatives that @HusseinHollandreplied to.  But that evolved into temp sensors and fuel curves; way above my head.  I was hoping that as "hard to find" became NLA, someone would forge ahead with a workable solution, whether that be an FPR from a motorcycle, or some other part(s) that had been shown to work.
Here's 78.  The barbs are different but the orientation is about right.  The ZX looks about the same I think the mounting bracket might be slightly different.  I found an eBay FPR that is slightly different.  Says it's for the ZX's.
https://www.ebay.com/itm/304857213677?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=-EOJC1W2RHK&sssrc=2047675&ssuid=bBzFtXzvTQO&widget_ver=artemis&media=COPY
1980
If I did my research right, the Toyota Celica Supra & Cressida FPRs should operate around the correct pressure.
I was thinking that with the female threaded end you could possibly find a barb that would allow you to connect it to the fuel rail with a short piece of hose.
1 hour ago, SteveJ said:
Has anybody ever looked at this Beck/Arnley 158-0073? https://www.amazon.com/Beck-Arnley-158-0073-Injection-Pressure/dp/B000CB03EA
It came up in a search for L-jetronic fuel pressure regulator. I haven't drilled down enough to see if the specs are available.
I was wondering about that one myself.  It turns out the one Zed Head linked on Rock Auto (post #2 above) crosses to that same part number.
Added note to which post I referenced.
I looked up some other images without the plug in the female thread.  It does look like a pipe thread, so probably JIS, which is interchangeable with BSP threads.  Finding a hose barb, or even an adapter to thread it onto the end of an extruded fuel rail should be no problem.  The unanswered question is what the pressure rating for this FPR is.  I tried to look up the specs, and even found a table to cross-reference a dozen equivalents.  But none of them go beyond listing what cars they're a direct fit for.  EDIT: After some more digging on Toyota forums using the OEM part number, I'm seeing the expected fuel pressure at idle around 36psi, which is correct for our cars.
Added more info
The VW part has two flared nipples, for rubber hose and clamps.  The male threads are for fastening to a mounting bracket.  The adjustable Bosch FPR that I had used the same design.  I think that I modified an old broken Nissan FPR and used its bracket to mount the Bosch.
The 37 psi shown as the spec. is almost certainly a typo.  The Beck Arnley piece is in the same list of VW FPR's.  Circling back...
  • Who's Online   1 Member, 0 Anonymous, 296 Guests (See full list)
