Randalla Posted October 12, 2023 Share #1 Posted October 12, 2023 Working on a customer's 1973 240Z with early AC compressor. Looks like removing the bad fuel pump and installing a new one will require substantial disassembly. Is there an easier way to swap the pump without disassembling half the car? Got off the two nuts on the top of the pump but can't find a way to reach the bottom one. Link to comment Share on other sites More sharing options...
SteveJ Posted October 12, 2023 Share #2 Posted October 12, 2023 You'll have to work the compressor loose and pray there is enough flex in the AC lines. 1 Link to comment Share on other sites More sharing options...
Randalla Posted October 12, 2023 Author Share #3 Posted October 12, 2023 I have the compressor lose but there is very little ability to move it more than an inch or two, not enough to allow access to the final nut. Link to comment Share on other sites More sharing options...
SteveJ Posted October 12, 2023 Share #4 Posted October 12, 2023 5 hours ago, Randalla said: I have the compressor lose but there is very little ability to move it more than an inch or two, not enough to allow access to the final nut. Keep in mind that I didn't say I was able to do it successfully. When I encountered that, the owner's son worked at a Kia dealership, and he had one of the mechanics in the service department tear out the non-functioning AC system. It might be that the system will need to be drained of refrigerant if it's still functional, get the hoses off the compressor, and replace everything after you fix the fuel pump. 2 Link to comment Share on other sites More sharing options...
siteunseen Posted October 12, 2023 Share #5 Posted October 12, 2023 I remember removing the brackets that hold the compressor to swap out a bad fuel pump. One on the bottom and then the fan had to come off to get the top one. It was an ordeal for sure. York system lives in storage now. 1 1 Link to comment Share on other sites More sharing options...
jfa.series1 Posted October 12, 2023 Share #6 Posted October 12, 2023 Had to do this PITA repair so very many years ago. Possibly seperate the compressor from the bracket to increase manuverability of the bracket? 1 Link to comment Share on other sites More sharing options...
Randalla Posted October 12, 2023 Author Share #7 Posted October 12, 2023 I have the compressor and bracket separated but still no room to get the bottom bolt. Looks like I'll have to go in from the bottom, necessitating draining radiator, removing lower hose and removing alternator. Arghhh! 1 Link to comment Share on other sites More sharing options...
SteveJ Posted October 12, 2023 Share #8 Posted October 12, 2023 That's exactly why I was looking at the compressor and mounting bracket from Nostalgic AC. It mounts on the other side of the block. Link to comment Share on other sites More sharing options...
DatsunZGuy Posted October 12, 2023 Share #9 Posted October 12, 2023 (edited) This might be a good opportunity to encourage the owner to switch to an R134 system where the AC compressor mounts on the other side of the block. In my situation, most of the emission plumbing was removed and the compressor now resides where the air pump was previously. Edited October 12, 2023 by DatsunZGuy 1 Link to comment Share on other sites More sharing options...
psdenno Posted October 12, 2023 Share #10 Posted October 12, 2023 Consider leaving the mechanical pump in place and installing an electric pump. That worked for me for about 25 years on my '71 with York AC compressor. When I switched to a newer AC system, I stayed with the electric pump, removed the mechanical pump, and installed a block off plate in its place. 2 Link to comment Share on other sites More sharing options...
Popular Post Randalla Posted October 14, 2023 Author Popular Post Share #11 Posted October 14, 2023 Not a fun job, but got it just about wrapped up. I did have to drain the radiator, remove the lower hose, remove the alternator, and completely unbolt the large compressor bracket. It was a two person job to hold the compressor up while lining up all the bolt holes to re-attach the large steel bracket. Now that I've done it, I could do the job in half the time (isn't that always the way?). A fair amount of time was spent assessing how to tackle the job. Thanks for your input guys. 6 Link to comment Share on other sites More sharing options...
