Headlight problems: It's always the last place you look.
SteveJ
Nice sleuthing!
Having not removed headlamps on a Z yet - based on your post, it all removes from the wheel well with the splash guard removed, obviously. I'm looking at Holley 7" 'retrobright' style LED lamps. Not a fan of LED's at all, however an acquaintance has them on his Fiat Spider, and they look good and project well. Having reduced current draw compared to converting to H4 80W's makes sense.
3 minutes ago, HusseinHolland said:
Nice sleuthing!
I would advise against those, @HusseinHolland
  1. That pigtail on the back of the light will make it where it won't fit in an S30 headlight housing. You would have to cut a hole in the housing to run the pigtail out. Then you would have to worry about water getting into the housings, and you would also have more issues integrating it. To me, it's more pain than it's worth.
  2. I can't guarantee they are polarity independent. The Fiat Spider has 2 positives and one negative. The Z has 1 positive and two negatives. If the Holley headlights aren't polarity independent, you'll have even more work figuring out how you can integrate relays into the wiring harness.
Holley headlight:
Inside an S30 headlight housing: (Image from https://www.zeddsaver.com//collections/exterior/products/restored-headlight-bucket-set)
That is why I use Hella 7" housings or Koito housings. Paired with the Auxito H4 LED bulbs. It works. As an added bonus, the Auxito bulbs are not polarity dependent.
I know you like to experiment, but please trust me on this one. Here are links to my recommended parts:
Hella H4 housings:       https://www.amazon.com/dp/B001G76Q2W
or
Koito H4 housings:       https://parts.toyotasouth.com/oem-parts/toyota-headlamp-assembly-8111060p70
Auxito H4 LED bulbs:       https://www.amazon.com/gp/product/B07TQLK6SH
By the way, Koito is an electrical parts supplier to the Japanese auto industry. You may still have some Koito bulbs in your car. Toshiba was another common supplier back in the day.
All together, it would be about $125 to go my route. With the Holley lights, you're starting out over $380, and then you still have the integration issues.
  • Agree 1
Holley headlight:
or
Thank you for the caution Steve!
I have H4 7" housings from my X1/9 original pop up headlamps. So, I would just need to get the Auxito H4 LED bulbs to make this happen 🙂 - Any chance you have a pic of the lighting?
That's the great thing. H4 housings are H4 housings. The ones from the X1/9 should work just fine.
I don't have any photos, but for the people who have that set up, I have never had a complaint. I have those bulbs in both of my Zs. As a matter of fact, I did that for a friend's 280Z, and he then brought his other over for me to convert that one, too.
Just to follow up on the initial post...
I returned to the scene of the crime today. I cut off the connector because it had some damaged wire and put a new 9003 connector on. Both headlights worked.
Here's how the connector looked. You can see missing insulation from the positive and burn marks on the insulation on the high beam wire.
My friend had some small BA15 bulbs so I replaced the side marker bulbs. The front left and rear right had corrosion, so I used a wire brush on a dremel to remove the corrosion. The front lights also were attached without the weatherstrip block, so I got those in place to protect the lights better.
Afterward I convinced the owner that LED bulbs, especially the headlight bulbs, would be a good idea. I hope he follows up with doing that. Yes, he does have my list.
  • Who's Online   1 Member, 1 Anonymous, 769 Guests (See full list)
