October 29, 20231 yr comment_658800 On finding one I hope I didn’t imply that it was easy but they are out there. Personally I look for the permanent fix in order to move on to the next project. It all comes down to the end result you are looking for. Everyone has a budget which I fully understand. Link to comment https://www.classiczcars.com/forums/topic/68643-am-i-looking-at-a-monster-vacuum-leak-here/?&page=3#findComment-658800 Share on other sites More sharing options...
October 29, 20231 yr comment_658815 On 10/29/2023 at 1:27 AM, Captain Obvious said: Then I sawed off the EGR section, milled it flat, and made a block off plate: Quite a bit of work, but turned out great, and since the sealing into the runners is done with bolts, that plate doesn't even really need to seal. That's fantastic work Sir. I had the sense to saw mine off but the bottom of my tunnel was rotted farther back and too jagged for a plate. I was going to do as Zedhead mentioned, just put a big 'ol wad of JB Weld in there but lucky for me I found an N42 on an old junkyard 280. Link to comment https://www.classiczcars.com/forums/topic/68643-am-i-looking-at-a-monster-vacuum-leak-here/?&page=3#findComment-658815 Share on other sites More sharing options...
November 23, 20231 yr Author comment_659705 So I was able to get the plug at the end of the EGR gallery opposite where the EGR valve would be. Looks like it's entirely jam packed with this material. From the one plug I was able to get out earlier, showing the port from the EGR gallery to the manifold, it looks like somebody soldered the ports shut and then packed this stuff into the manifold that really does seem like casting sand. ... or it was like that from the factory. ::shrug:: Link to comment https://www.classiczcars.com/forums/topic/68643-am-i-looking-at-a-monster-vacuum-leak-here/?&page=3#findComment-659705 Share on other sites More sharing options...
