Posted November 7, 20231 yr comment_659127 VERY EARLY L24 240Z Blocks need a New Home: Complete engine E31 Block, E31 Head, Early Type Oil Pan, Fuel Pump, etc. Serial Number 36xx Complete block (E31 Block) Will check on olil pan tonight. Serial Number 37XX Located in Los Angeles. Link to comment https://www.classiczcars.com/forums/topic/68663-very-early-6970-l24-240z-engine-blocks-need-a-new-home/ Share on other sites More sharing options...
November 7, 20231 yr comment_659128 Why are you hiding the serial number? Seems suspicious. . . Edited November 7, 20231 yr by Zed Head +you Link to comment https://www.classiczcars.com/forums/topic/68663-very-early-6970-l24-240z-engine-blocks-need-a-new-home/#findComment-659128 Share on other sites More sharing options...
July 9, 2024Jul 9 comment_667164 I also wonder why the subterfuge regarding the serial numbers. I have a low number first year Z that doesn’t have the original engine and I would love to find it. Link to comment https://www.classiczcars.com/forums/topic/68663-very-early-6970-l24-240z-engine-blocks-need-a-new-home/#findComment-667164 Share on other sites More sharing options...
July 9, 2024Jul 9 comment_667194 You gotta get into VIN numbers above 600 for engine blocks in the 3600 range. Link to comment https://www.classiczcars.com/forums/topic/68663-very-early-6970-l24-240z-engine-blocks-need-a-new-home/#findComment-667194 Share on other sites More sharing options...
