Vapor Tank Question
chaseincats
19 hours ago, chaseincats said:
This hit me today.  Why not plug the metal line in the engine bay that comes from the vapor tank into the t-connector that the carbon canister's vacuum actuator outlet ordinarily would plug into?  The vapors would still be going into the intake manifold, just through a different opening.
This would create a large vacuum leak.  It might even overpower the valve in the gas cap and pull a vacuum on your tank.  That would be bad.  If the seal in your canister cap is bad you might have a vacuum leak anyway.  Might partially explain your "lean" problems.
You could just block the line completely and get a two way vented gas cap.  Maybe.  Gas caps are hard to find.  Although the seal on mine was destroyed and it was two-way anyway.  Move the smell to the outside back of the car.  Like the old days.
Doesn't having the carbon canister connected properly create a semi-vacuum leak?  The seal is indeed bad in the vacuum portion of the canister.
It's a controlled leak.  A small one that is only open when the eninge is off-idle.  The vacuum control hose is on a "ported" vacuum souce on the throttle body.
Right, so why wouldn't plugging the metal tank line into the ported line that goes into the throttlebody work?
Posted (edited)
18 minutes ago, Yarb said:
Go to @Dave WM post and see how he found one I believe off of an older pathfinder that worked. You may find that your issue is back at the tank. There’s a check valve in place back there as well.
If Dave WM has found a canister from a newer vehicle that works that would probably be the simplest most direct way to go.  The concept is the same and Nissan kept stuff that worked around for decades.  My 95 Pathfinder had an AAR valve that was essentially the same as a 1975 280Z's (I think, it's sold now, can't double-check).  Same basic shape and function.
Edited by Zed Head
1 minute ago, Zed Head said:
If Dave WM has found a canister from a newer vehicle that works that would probably be the simplest most direct way to go.  The concept is the same and Nissan kept stuff that worked around for decades.  My 95 Pathfinder had an AAR valve that was essentially the same as a 1975 280Z's.  Same basic shape and function.
Ah that topic - I believe it was from a mid-90s pathfinder too
There would be no "control".  You might also flood the intake with vapor as the car sits in the sun.  Vaporization and condensation.  Engineers spent a lot of time and effort trying to figure out how to handle the vapors in a way that solves and avoids problems.  I'm sure that there are people out here who've tried to outthink the engineers and ended up back at their solution after going around in circles.
The charcoal canister and its control system is really simple.  The hardest part of the Pathfinder mod is probably mounting the canister.
