Posted November 14, 20231 yr comment_659440 Has anyone had any issues with the shifter bushings sold by zcardepot not fitting? I installed the pivot bushing at the bottom of the shifter, and pressed the two bushings into each side of the shifter itself. However, when I tried to stick the shifter in between the ears of the transmission to fit the shifter back into place, it wouldn't fit, the shifter bushings are just too wide. I tried using some moderate force, and one of the bushings was actually pushed out of the shifter itself by the ear on the transmission and flew off into oblivion, so now I'm having to order another bushing. Anyone ever encounter this before? Any searching I've done seems to just yield people using solid bushings or saying how easy the process is, but that shifter definitely did not want to fit in between the ears on the transmission with those bushings pressed into each side of the shifter. Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/ Share on other sites More sharing options...
November 14, 20231 yr comment_659441 Are these plastic or brass? Link to the part? Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/#findComment-659441 Share on other sites More sharing options...
November 14, 20231 yr Author comment_659442 1 minute ago, heyitsrama said: Are these plastic or brass? Link to the part? These are plastic https://zcardepot.com/products/shifter-bushing-kit-oem-240z-260z-280z-280zx# I'm mildly annoyed, it was nowhere close to fitting, and I don't believe my transmission is to blame, either. Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/#findComment-659442 Share on other sites More sharing options...
November 14, 20231 yr Author comment_659444 Somewhat of an update, I did manage to locate where the other bushing flew off to, but I can't seem to get the shifter to align enough for me to slide the pin through, going to have to get at it from underneath the car from the look of things because I can't see to align it, and it's going to need tapped in based on the resistance I'm feeling. Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/#findComment-659444 Share on other sites More sharing options...
November 14, 20231 yr comment_659445 Maybe the "ears" on your gearbox have been pushed together to compensate for worn bushes at some time in the past. that seems to have been done to mine and I had to heat them and pry them apart again to get everything aligned right. Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/#findComment-659445 Share on other sites More sharing options...
November 14, 20231 yr comment_659447 You could always sand the bushings a little until they fit the way you like Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/#findComment-659447 Share on other sites More sharing options...
November 14, 20231 yr comment_659457 I have these in mine. Cheap too. http://www.atlanticz.ca/zclub/techtips/shifterbushing/index.html Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/#findComment-659457 Share on other sites More sharing options...
November 15, 20231 yr comment_659459 I have a new set I never used you can have but would probably cost more to ship.🤦♂️ Link to comment https://www.classiczcars.com/forums/topic/68678-shifter-bushings-dont-fit/#findComment-659459 Share on other sites More sharing options...
