Posted November 29, 20231 yr comment_659835 I have some factory vinyl I plan to install in my '70. It is in very good shape except for a section on the transmission tunnel. It is a strip about 10" tall along the floor on the passenger side. It is unusually stiff and wont lay flat against the jute even after I glue it down. I have tried using Meguiars Back to Black to soften it up but that didnt have any impact. I thought about Vaseline or maybe even shoot it with a hair dryer. Does anyone have any suggestions? Thanks Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/ Share on other sites More sharing options...
November 29, 20231 yr comment_659837 Consider warming it with a hair dryer or heat gun. It should get pliable enough to work into the proper position. Edited November 29, 20231 yr by jfa.series1 Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659837 Share on other sites More sharing options...
November 29, 20231 yr comment_659838 I would say lay it out in the Sun but I see you’re from Indiana. Probably not the best time of the year. Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659838 Share on other sites More sharing options...
November 29, 20231 yr comment_659839 Heat is the treat. Not too much. Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659839 Share on other sites More sharing options...
November 30, 20231 yr comment_659848 The Meguiars product to soften it up is Hyper Dressing. But it'll take a while... Heat carefully applied should work to reshape, but it depends on what has damaged it. Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659848 Share on other sites More sharing options...
November 30, 20231 yr comment_659859 Laying it out in the sun was going to be my suggestion also. Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659859 Share on other sites More sharing options...
November 30, 20231 yr Author comment_659861 Thanks everyone for the suggestions. I made a mistake. I used Meguiars Hyper dressing on it. Not back to black. It treated the rest of the vinyl very well. Just not this one section. I cant imagine what would have happened to this one section. Very odd. I will give the hair dryer a try and see how it goes. But yes, leaving it out in the sun will probably not work in Indiana. 😄 Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659861 Share on other sites More sharing options...
December 3, 20231 yr comment_659908 Rubber, plastic and vinyl get crispy here in Arizona. I've used Hyper Dressing many times to breathe some life back into them but it's not instantaneous. I've put parts slathered with HD in a plastic bag for 2-3 weeks ... Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659908 Share on other sites More sharing options...
December 4, 20231 yr Author comment_659937 On 12/3/2023 at 5:43 PM, cgsheen1 said: Rubber, plastic and vinyl get crispy here in Arizona. I've used Hyper Dressing many times to breathe some life back into them but it's not instantaneous. I've put parts slathered with HD in a plastic bag for 2-3 weeks ... I am a little reluctant to use heat since it is possible that was the cause of the damage. But heat might be my only choice. Hyper dressing definitely made the rest of the vinyl soft. Just not that one section. Maybe I will give it another try. Front and back of the section. Link to comment https://www.classiczcars.com/forums/topic/68695-stiff-factory-diamond-vinyl/#findComment-659937 Share on other sites More sharing options...
