December 8, 20231 yr comment_660061 I actually did check all of the washer part numbers on the internet. None of them came up as the "D" washer shape. Who knows. Maybe they were only "D" on the assembly line, and normal as a replacement part https://www.nissanpartsdeal.com/parts/nissan-washer~08915-43610.html Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660061 Share on other sites More sharing options...
December 8, 20231 yr comment_660064 What about a local paint/body shop or auto paint store? Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660064 Share on other sites More sharing options...
December 9, 20231 yr comment_660068 Put in an order from Mc Master Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660068 Share on other sites More sharing options...
December 9, 20231 yr comment_660081 I was thinking number 71 in the diagram. That also calls for 8 each Superseded now see second pic. Still available from Nissan. Edited December 9, 20231 yr by Terrapin Z added info Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660081 Share on other sites More sharing options...
December 12, 20231 yr Author comment_660139 Guys, just a quick update. So the left washer in the pic is McMaster and right one from MSC (link below). I installed the MSC as the inside diameter is a better match with the M6 bolts which you need there. McMaster has more options too but they are out of stock for many. https://www.mscdirect.com/product/details/06772388 Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660139 Share on other sites More sharing options...
December 13, 20231 yr comment_660170 This is my non-impressive collect ATM. But the good news is that I have a very very close replacement washer source. These are 17.6 mm OD with a 6.4mm ID. (The web site says 18mm OD, but they are lying, I mean nominal…..) They are nice and thin as well. Of course you have to create the flat spot yourself, then get them replated, but when you have to get it right, you have to get it right, right? https://belmetric.com/hv-140-steel-general-purpose-din-9021-fender-washer/?sku=WFE6X18YLW Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660170 Share on other sites More sharing options...
December 13, 20231 yr comment_660171 Ordered a set from my local Nissan dealer yesterday. Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660171 Share on other sites More sharing options...
December 13, 20231 yr comment_660172 Will be interesting to see what you receive Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660172 Share on other sites More sharing options...
December 13, 20231 yr comment_660173 Should be here Friday. Coming out of one of the dist. Whse in Tx. McMaster Car order came in yesterday. $26 with shipping. Think I pulled the trigger way to soon. I’ll post pics of both when I pick up the Nissan washers. Edited December 13, 20231 yr by Yarb Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660173 Share on other sites More sharing options...
December 13, 20231 yr Author comment_660175 On 12/9/2023 at 5:08 PM, Terrapin Z said: I was thinking number 71 in the diagram. That also calls for 8 each Superseded now see second pic. Still available from Nissan. Hopefully it is not this one. Was trying to find a pic of the part number and saw this 😄 Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660175 Share on other sites More sharing options...
December 13, 20231 yr comment_660179 On 12/13/2023 at 7:17 PM, MH77280Z said: Hopefully it is not this one. Was trying to find a pic of the part number and saw this 😄 It did label it as Washer Plain, so i am not 100% sure. That bag shows a -4351A which might again be different than a -43510. I also don't see the -4351A as part of the superseded list. Which part number did you order from Nissan? -43610 (Zed's) or the -43510 (mine) or both? Edited December 13, 20231 yr by Terrapin Z spelling Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660179 Share on other sites More sharing options...
December 13, 20231 yr comment_660180 4351A is what I ordered. Guess I’ll have extra washers. Edited December 13, 20231 yr by Yarb Link to comment https://www.classiczcars.com/forums/topic/68711-d-washers-for-fenders/?&page=2#findComment-660180 Share on other sites More sharing options...
