Posted July 3, 200321 yr comment_42773 Is the swaybar stud supposed to be much smaller that the hole in the end of the swaybar? I attached a picture, it looks like it must be missing something to keep it from moving around. Link to comment https://www.classiczcars.com/forums/topic/6872-sway-bar-ends-to-big/ Share on other sites More sharing options...
July 3, 200321 yr comment_42783 that hole in the end of the swaybar is for the bushings to sit in. Link to comment https://www.classiczcars.com/forums/topic/6872-sway-bar-ends-to-big/#findComment-42783 Share on other sites More sharing options...
July 3, 200321 yr comment_42793 Here is a diagram of an installatiopn, and a picture of a set of what you need for a complete set of end links. You need: 8 bushings (rubber or polyurethane) 8 cupped washers if using polyurethane bushings The images below show polyeurathane bushing kits. Courtesy of http://www.energysuspension.com/index.html Link to comment https://www.classiczcars.com/forums/topic/6872-sway-bar-ends-to-big/#findComment-42793 Share on other sites More sharing options...
July 3, 200321 yr Author comment_42794 Gotcha,, I should have looked closer at the new urethane, it has a lip that will set right into the "loop" on the end of the swaybar.Thanks Link to comment https://www.classiczcars.com/forums/topic/6872-sway-bar-ends-to-big/#findComment-42794 Share on other sites More sharing options...
