6 hours ago, Captain Obvious said:
Wow! That must have made quite the noise!   :excl:
Well it did take 5 hours to get the blessed thing off (in prep for the Quaife ATB going into it)! My wife made some noise though as I told her I’d be just a couple of hours tops 🤣 she should know better by now!
Things just take that much longer when you’re working on the drive between 3°-0°C with wind blowing across you. Helps go faster if you can feel your fingers!
Edited by AK260
  • 3 weeks later...
I took the 260Z for a drive today. When I stopped for gas, I could smell coolant, though I couldn't find a smoking gun. When I got home, I looked closer, and it appears I may not have tightened some hose clamps when I replaced the water pump. I'm letting the car cool down enough so I can work on the lower clamp on the lower radiator hose.
They have a depot here in the states to keep the shipping cost down. Spoke to one of the partners a year ago before I bought mine and he explained the process. He said they wouldn’t sell many tanks if they shipped them directly from Europe.
Good to know.  I am concerned about the area where I welded on my gas tank.  I chose to remove a "drain" that was added by the shop that cleaned and coated the inside of my tank.  Though I believe I got it air tight again, I fear it may develop a leak in that corner of the tank.  It is good to be aware of options.
