Posted January 8, 20241 yr comment_660855 Hi guys, quick question. Rockauto seems to have reman 5-pin AFMs in stock where the Canada spec one is half the price of the federal emissions (guessing that means USA) spec version. Anyone know what is the mechanical difference between these? Link to comment https://www.classiczcars.com/forums/topic/68766-rebuilt-afm-question/ Share on other sites More sharing options...
January 8, 20241 yr comment_660867 You might find something in the FSM. I'd guess that the Canada model runs richer at certain air flow and RPM ranges since the emissions regs were less stringent. The Fed model would be lean for the catalytic converter. Might be described in the Emissions chapter. I see that Rockauto put the AFM's in Exhaust & Emission instead of Fuel & Air. Odd, but might tell something. https://www.rockauto.com/en/catalog/nissan,1980,280zx,2.8l+l6,1209316,exhaust+&+emission,mass+air+flow+(maf)+sensor,5128 Link to comment https://www.classiczcars.com/forums/topic/68766-rebuilt-afm-question/#findComment-660867 Share on other sites More sharing options...
January 8, 20241 yr Author comment_660877 9 hours ago, Zed Head said: You might find something in the FSM. I'd guess that the Canada model runs richer at certain air flow and RPM ranges since the emissions regs were less stringent. The Fed model would be lean for the catalytic converter. Might be described in the Emissions chapter. I see that Rockauto put the AFM's in Exhaust & Emission instead of Fuel & Air. Odd, but might tell something. https://www.rockauto.com/en/catalog/nissan,1980,280zx,2.8l+l6,1209316,exhaust+&+emission,mass+air+flow+(maf)+sensor,5128 Gotcha, so it wouldn't be the spring tension that would be different, it would be the circuit board? Edited January 9, 20241 yr by chaseincats Link to comment https://www.classiczcars.com/forums/topic/68766-rebuilt-afm-question/#findComment-660877 Share on other sites More sharing options...
