Rear tie down hooks
Posted (edited)
As I plan to keep the car stock, secured these rear tie down hooks from ebay. They seems correct per the FSM to be rear tie down hooks. Left one aligns with the 3 bolt holes I have on the body. The right one #6 seems a bit different than the left. #6 has 3 holes almost vertical  in the pic vs the one i received which is a mirror copy of the left.
Anyone has them installed?
Edited by MH77280Z
Thanks for sharing. So mine are correct rear ones. Need to find out what previous owner did to one of the right holes!!!
They were advertised as front on ebay and I took a chance as they were listed fairly cheap 😀
Edited by MH77280Z
  • 3 weeks later...
Update…
Project complete. My right tie down on the 77 280z was a bit different. 3 vertical bolts per the 77 shop manual above - found one piece on eBay. The left one I posted above fitted fine.
Edited by MH77280Z
