Gluing approach on 240z sign of glovebox
jalexquijano
12 hours ago, CanTechZ said:
As my glove box door is currently taken apart here is a reference picture showing the emblem with the pins and retaining clips intact, as it was originally assembled.
so if i already purchased a JDM reproduction emblem the only way to stick is using gorilla tape?
Already installed the emblem. However, while adjusting the height so the lid could close properly 2 of the plastic tabs broke. I decided to order the skillard aluminium glove box and rear lid.
Edited by jalexquijano
Sometimes you have to adapt and fabricate when necessary. I understand this is not the solution you are looking for. Figure out where it’s binding and make an adjustment as needed. Once you move away from factory specs customization always seems to create problems such as what you’re running into now.
  • Agree 1
  • 4 months later...
Well this was my approach to replacing the original cardboard and fabricating a glovebox. My only  concern is how ro remove the clock gauge if the led burns and i need to replace it.  Also if i need to remove or service the ac evaporator it will be difficult as the back panel is glued with silicone.
