Posted February 13, 20241 yr comment_662004 Putting the front suspension back together. I bought brand new KYB 361002 struts for the front strut tubes. Is it normal to have to drill out the spring isolator to remove the “D” shaped opening for the shock threads to pass through? Pics below showing the issue. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/ Share on other sites More sharing options...
February 13, 20241 yr comment_662006 No. I had KYB's and the shafts were D-shaped. Drop-in replacements. Maybe KYB is cost-cutting, or made a mistake, or maybe you got counterfeits. Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662006 Share on other sites More sharing options...
February 13, 20241 yr Author comment_662007 Got them directly from rock auto, so I doubt they’re fakes. Maybe it’s the cost cutting you mentioned.I wonder if it’s better to round out the isolator, or attempt to grind down the shock threads to fit the D shape. Rounding the isolator would obviously be easier, but I’m open to suggestions?Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662007 Share on other sites More sharing options...
February 13, 20241 yr comment_662008 You need the D to hold the shaft while you tighten the nut. Otherwise it will spin. Did you get four? Are they all that way? Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662008 Share on other sites More sharing options...
February 13, 20241 yr Author comment_662009 You need the D to hold the shaft while you tighten the nut. Otherwise it will spin. Did you get four? Are they all that way?Good point. I’ll have to grind the shock threads then.I bought the KYB 361001 for the rears, as is recommended. I’ll check those out when I get home and see if they suffer the same problem. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662009 Share on other sites More sharing options...
February 13, 20241 yr comment_662010 I would check with Rockauto or KYB first! Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662010 Share on other sites More sharing options...
February 13, 20241 yr Author comment_662011 I would check with Rockauto or KYB first!Valid, I’ll see if I can get in touch with KYB first. Ugh.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662011 Share on other sites More sharing options...
February 13, 20241 yr comment_662012 I bought the same struts from Rock Auto June 2022 and I dont think I had that problem. That is something I would have remembered for sure! I think I would try and contact KYB, if that is possible. Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662012 Share on other sites More sharing options...
February 13, 20241 yr Author Popular Post comment_662014 Dude. Am I going blind? Or my garage lighting is severely lacking.The shaved threads were there the whole time. I dunno how I missed that. Anyways, carryon.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662014 Share on other sites More sharing options...
February 13, 20241 yr comment_662019 You've been conditioned to expect problems. Reprogram! Link to comment https://www.classiczcars.com/forums/topic/68819-kyb-361002-shock-won%E2%80%99t-fit-rubber-spring-isolator/#findComment-662019 Share on other sites More sharing options...
