I put a new steering rack in my car that has right hand inner tie rods on both sides.  I bought 2 MOOG ES2109R right side tie rods and they do fit but on the driver's side it's a bit too long and I don't have much adjustment ability.  Also its pointed slightly forward as opposed to the passenger side where it points sightly rearward.
What is everyone using for drivers side outer tie rod with right hand thread?
Thanks for your feedback.  I just rechecked and I was off center on the rack a little bit and after centering it I may now have enough travel on each side.
Do you have any concerns about the driver's side pointing forward?
1/78 280. Both of mine point forward where if you are looking at each side the tie rod width wise is pretty much half and half. In other words you can see half the ball. Looking at the dust shield for the rotor.
Edited by Yarb
