Posted March 11, 20241 yr comment_663003 Two questions on the five clipped fender washers on each side of the hood. Two questions: 1) Do these install with the flat up so that the washer is not as visible when the hood is closed, or do these install with the flat down to not interfere with the lower lip of the fender (just below the washers). 2) Can someone send me these two dimensions (A and B)? Link to comment https://www.classiczcars.com/forums/topic/68855-240z-top-fender-washers/ Share on other sites More sharing options...
March 11, 20241 yr comment_663013 Where did you find these washers? Link to comment https://www.classiczcars.com/forums/topic/68855-240z-top-fender-washers/#findComment-663013 Share on other sites More sharing options...
March 11, 20241 yr comment_663016 Here is a previous discussion about clipped washers, also called D washers. In post 11 I shared dimensions of the ones I found on my 7/70. The discussion also lists some sources for these. Link to comment https://www.classiczcars.com/forums/topic/68855-240z-top-fender-washers/#findComment-663016 Share on other sites More sharing options...
