Posted March 22, 20241 yr comment_663272 You know what we really need? New sprayer nozzles. Mine are mostly shot, and I hate them. Too bad there isn't a better nozzle out there. Link to comment https://www.classiczcars.com/forums/topic/68870-windshield-sprayer-nozzle/ Share on other sites More sharing options...
March 22, 20241 yr comment_663274 It would be nice to see a reproduction but I bet they would be surprisingly expensive. They are more complicated than they look Link to comment https://www.classiczcars.com/forums/topic/68870-windshield-sprayer-nozzle/#findComment-663274 Share on other sites More sharing options...
March 22, 20241 yr comment_663275 I’ve struggled with nozzles too. On my last personal Z, I put a pair of two-outlet each sprayers right on the cowl (from maybe a early 2000’s Altima?), ran the hose through a new hole in the firewall to get in there and enjoyed a full volume 4 spray pattern on the windshield. They were small black and low profile. I’ve since seen all manner of aftermarket spray nozzles that surface mount. Just an idea. I might be able to scrap up a set of stock nozzles if you really need some bad…. Found a picture of my sprayers on the cowl! From 2010! Dang I miss that car… Edited March 22, 20241 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/68870-windshield-sprayer-nozzle/#findComment-663275 Share on other sites More sharing options...
March 22, 20241 yr comment_663276 Amazon is “a-wash” with spray nozzles! (Ha) Only thing on a 510, the cowl to windshield angle is too sharp, and the cowl is too close to the windshield to use these. Would have to put them on the hood. Not as “slick” a solution. Hey don’t Z’s have both RHD and LHD nozzle holes in the firewall? You “could put four nozzles in and get better volume! Or is that 510’s….. Arghhhhh Edited March 22, 20241 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/68870-windshield-sprayer-nozzle/#findComment-663276 Share on other sites More sharing options...
March 22, 20241 yr comment_663278 Maybe something like these could be adapted. https://www.cjponyparts.com/cj-classic-trucks-windshield-washer-spray-nozzles-pair-chevrolet-c10-1960-1966/p/WWSN1/?year=1966&srsltid=AfmBOorzg5qObYNknNhDqvXyS_t8abztLRhItbJum_qInnfrWnpOpfubXSM This Mopar kit may have some potential, too. https://www.jegs.com/i/OER/691/K6671/10002/-1?srsltid=AfmBOoojCCedoDtafRJ2MaSH0UE_E_OP_mHOQiGg3JuaZmjOAOAouJVNd2o Link to comment https://www.classiczcars.com/forums/topic/68870-windshield-sprayer-nozzle/#findComment-663278 Share on other sites More sharing options...
March 22, 20241 yr comment_663283 3 hours ago, zKars said: I’ve struggled with nozzles too. On my last personal Z, I put a pair of two-outlet each sprayers right on the cowl (from maybe a early 2000’s Altima?), ran the hose through a new hole in the firewall to get in there and enjoyed a full volume 4 spray pattern on the windshield. They were small black and low profile. I’ve since seen all manner of aftermarket spray nozzles that surface mount. Just an idea. I might be able to scrap up a set of stock nozzles if you really need some bad…. Found a picture of my sprayers on the cowl! From 2010! Dang I miss that car… That was a fabulous car! Link to comment https://www.classiczcars.com/forums/topic/68870-windshield-sprayer-nozzle/#findComment-663283 Share on other sites More sharing options...
