Attaching rear license plate bracket
fusion
Hello,
This is probably a stupid question, but how is the rear license plate bracket supposed to attach to the body?  It looks like the only mounting points are the 2 standoffs on the bottom, but they are just through holes and not threaded.  I was surprised to see they weren't threaded.  I bought the car in pieces so I never saw how it was attached.
Not 100%, but typically there are hook-like devices to hold one side and the screws lock it in so that it can't come out of the hooks. Not sure what exactly you're trying to fit.  But here are some things that look like they might be involved.  Modified your picture.
I went to BAT to try to find an example and found that people are doing all kinds of different things.  Might be worth browsing aorund to get some ideas.  Many people just use the four screw holes, apparently.  Naked plate.
https://bringatrailer.com/datsun/280z/?q=280z
Some only have two holes and the bottom hooks.
They are very small plastic push pins similar to the interior but much smaller. Still available from Nissan. Expensive meaning they are $4.71 each but you have to buy a pack of 10.
p/n 79909-E4100
Send me a PM if you can’t buy just 2
  • Agree 2
p/n 79909-E4100
Yes! The middle tag part slides into the other panels and is held in place by the small rivets like Yarb referenced.
Thanks everyone.  I should have clarified it's a 280z.  I don't believe there are any screws along the top edge.  I had recently come to the conclusion it must be push pins, thanks Yarb.  I'm surprised that the only attachment points are 2 small push pins.  I'll see what I have and if I need 2, I'll send you a message Yarb.
On 4/7/2024 at 12:27 PM, fusion said:
... I'm surprised that the only attachment points are 2 small push pins. ...
That's not the only attachment. It's held in place on both sides by the tail light surrounds and also by the license plate. If everything else is in place, it's kinda stuck there...
  • Who's Online   2 Members, 0 Anonymous, 707 Guests (See full list)
