November 4, 2024Nov 4 Author comment_671014 Have the jack that came with vin-51, can’t make out the markings, but has a clear enough decal….. anyone take a shot at the stamping? Couple different angles.. and lighting. Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671014 Share on other sites More sharing options...
November 5, 2024Nov 5 comment_671058 18 hours ago, dspillman said: Have the jack that came with vin-51, can’t make out the markings, but has a clear enough decal….. anyone take a shot at the stamping? Couple different angles.. and lighting. Looks like O A A, 1969 January 1st? Or O I A, 1969 August 1st? We talked about it here, Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671058 Share on other sites More sharing options...
November 5, 2024Nov 5 comment_671060 Im going with D A A or B A A Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671060 Share on other sites More sharing options...
November 5, 2024Nov 5 Author comment_671063 Looking at the decal, I’ve not seen one in black and white…. No red or colors…. Did early ones have a “more plain” appearance? Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671063 Share on other sites More sharing options...
November 5, 2024Nov 5 comment_671066 23 hours ago, dspillman said: Have the jack that came with vin-51, can’t make out the markings, but has a clear enough decal….. anyone take a shot at the stamping? Couple different angles.. and lighting. This appears to be a black and white copy (the machine used to make the copy could not read the red and blue colors) of the Skyline Hakosuka decal. JDM-CAR-Parts Link makes a good color decal: Keith Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671066 Share on other sites More sharing options...
November 5, 2024Nov 5 Author comment_671068 I see now….. color faded….. Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671068 Share on other sites More sharing options...
November 5, 2024Nov 5 Author comment_671076 Blocking, block, block….. Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671076 Share on other sites More sharing options...
November 5, 2024Nov 5 comment_671078 9 hours ago, dspillman said: Looking at the decal, I’ve not seen one in black and white…. No red or colors…. Did early ones have a “more plain” appearance? This is the jack of 1969 Z432, PS30-00055. Kats Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671078 Share on other sites More sharing options...
November 6, 2024Nov 6 Author comment_671081 Hard to believe these rivets were “factory”… Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671081 Share on other sites More sharing options...
November 6, 2024Nov 6 comment_671105 11 hours ago, dspillman said: Hard to believe these rivets were “factory”… Speaking of "I can't believe it's not butter factory". I don't know if this has been mentioned before as an early car feature, but the door trims on HS30 00150 had screws in the bottom of them. I originally thought they were someone's attempt to fix a wonky door card, but you can see on the passenger door the 2 (either side of the door handle). But I believe they were an early S30 feature. Have you seen them on HLS30 00051? Edited November 6, 2024Nov 6 by Gav240z Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671105 Share on other sites More sharing options...
November 6, 2024Nov 6 Author comment_671107 1 hour ago, Gav240z said: Speaking of "I can't believe it's not butter factory". I don't know if this has been mentioned before as an early car feature, but the door trims on HS30 00150 had screws in the bottom of them. But I believe they were an early S30 feature. Have you seen them on HLS30 00051? I've seen that on later cars, maybe through 6/70? in LHD HLS30 world. Speaking of doors, I was fortunate to have the original passenger, "right hand" side door, it had the 2 holes for the 2 door panel screws you showed pictures of. I was able to use a similar door, for left hand side. My big curiosity for the doors was the metal tab wire holder on the "floor" of original door, confirmed to be a "real thing" by other 69 car owners. I believe to maintain wiring for aborted door lights. Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671107 Share on other sites More sharing options...
November 6, 2024Nov 6 Author comment_671111 Well, I had heard of the red dot mirror......Check... Now a red dot radio, never heard of. but HS30. vin 4 clearly shows a red dot ..... One of Gavins pictures showed it.... in a February? #4 aus.car strange/odd peices... Link to comment https://www.classiczcars.com/forums/topic/68900-finally-found-a-69-240z-51-time-to-finish-a-30-year-multiple-owner-restoration/?&page=22#findComment-671111 Share on other sites More sharing options...
