Posted May 7, 20241 yr comment_665037 I have an issue where I can not get my low beams to work. When I turn the switch to the little dot the parking lights come on. When I turn the switch to the big dot then nothing happens. With the switch in this mode if I turn on the high beams they work. High beams off, no lights. I do not know where/how to start troubleshooting. Link to comment https://www.classiczcars.com/forums/topic/68956-78z-low-beams-not-working/ Share on other sites More sharing options...
May 7, 20241 yr comment_665039 The contacts inside the high/low switch at the base of the turn signal stalk get gummed up or corroded. Some people take them apart and clean up the contacts, some just squirt a bunch of contact cleaner in and give it a good workout. The combination switch supplies power to both the high and low beams. But the grounding in the switch at the signal stalk determines which beam lights. Link to comment https://www.classiczcars.com/forums/topic/68956-78z-low-beams-not-working/#findComment-665039 Share on other sites More sharing options...
