Posted May 12, 2024May 12 comment_665377 I was sanding the contact of the high beam switch today and I am such an arse. I dropped the metal piece that goes in the white clicker part. I am so mad, I cant find it in the garage. Anyone know if it is even possible to get one of these? Or does anyone have one? I am so screwed. A replacement switch is like $700. Link to comment https://www.classiczcars.com/forums/topic/68968-1978-280z-high-beam-switch/ Share on other sites More sharing options...
May 12, 2024May 12 comment_665379 This one is listed for $250 obo in the classified section. 77-78 completely rebuilt. Link to comment https://www.classiczcars.com/forums/topic/68968-1978-280z-high-beam-switch/#findComment-665379 Share on other sites More sharing options...
May 13, 2024May 13 comment_665402 On 5/12/2024 at 6:02 PM, gotham22 said: I dropped the metal piece that goes in the white clicker part. Have you got a pic of the part you lost? Link to comment https://www.classiczcars.com/forums/topic/68968-1978-280z-high-beam-switch/#findComment-665402 Share on other sites More sharing options...
May 13, 2024May 13 comment_665403 Are you talking about the little brass piece that fits in the slot in the plastic block? Link to comment https://www.classiczcars.com/forums/topic/68968-1978-280z-high-beam-switch/#findComment-665403 Share on other sites More sharing options...
May 13, 2024May 13 comment_665414 CO I think the OP might be referring to the hi-lo switch clicker, maybe?? Lost the little nubbin part? Link to comment https://www.classiczcars.com/forums/topic/68968-1978-280z-high-beam-switch/#findComment-665414 Share on other sites More sharing options...
May 13, 2024May 13 Author comment_665420 Its the nubbin that makes contact when you use the hi/lo switch. Link to comment https://www.classiczcars.com/forums/topic/68968-1978-280z-high-beam-switch/#findComment-665420 Share on other sites More sharing options...
