5 speed swap tunnel hole for the shifter
On 5/18/2024 at 7:46 PM, Zed Head said:
I assume that was the early body style shown in your sig?  Maybe that matters.
I used the 280Z 4 speed shifter on all of mine, it swaps right in.  Never tried the ZX shifter.
No, my '74 frame was always manual so I didn't make any alterations to the tunnel. I don't remember if my 260 even had a transmission when I got it. I did the turbo swap first thing. I have a wide ratio 5 speed and don't like the gearing so I'm running a close ratio ZX transmission.
The auto trans swap we did in a complete 260/280 frame was the 1975 all original 280Z from PA Museum car. We removed the original stock console, removed all the auto transmission specific hardware and trim, cut the forward part of the trans tunnel along the top sheet metal line, installed a 71B 5 speed with new boots on the trans, trans tunnel, and console.
You can't tell from the inside that it's a swap, you can from the engine bay.
In Wheeler dealers they changed the auto to a 5 speed transmission in a 240Z. They show cutting out the floor piece and installing the shifter. Watching it might help?
Definitely. Confirms not only the cut but all the stuff I’ve done up to this point as well
  • Who's Online   2 Members, 0 Anonymous, 510 Guests (See full list)
