Posted July 6, 200321 yr comment_42960 If you were rebuilding the engine in a '78 280z (for street use), what would your list of should do's and don't bother with include?Would headers be in order- an upgraded cam kit (does that affect the distributer)- computer changes- changes to the EFI?Any advice, tips, help, or redirection within the club would be greatly appreciated and welcomed- new to the club Link to comment https://www.classiczcars.com/forums/topic/6900-any-tips-for-l28e-rebuilding/ Share on other sites More sharing options...
July 6, 200321 yr comment_42974 With the L28 I am building I am porting the head, fitting a mild cam, looking at pistons/gaskets for ideal compression, upgrading injectors, fuel pump and fitting a larger 65mm throttle body.Als progammable engine management, most likely haltec or motec. Link to comment https://www.classiczcars.com/forums/topic/6900-any-tips-for-l28e-rebuilding/#findComment-42974 Share on other sites More sharing options...
